Timing chain question
Old Nov 12, 2008 | 07:44 AM
mastercoryd's Avatar
hey guys i have a quick question, i heard that on a lot of japanese cars you got to replace the timing belt after a certain amount of miles, but i know that maxima's have timing chains and didnt know if those also had to be replaced or if you just leave them alone, thanks
Old Nov 12, 2008 | 07:58 AM
Snypa's Avatar
Leave it alone, maybe tighten it if it sounds slack.
Old Nov 12, 2008 | 09:30 AM
heynow's Avatar
uh....you can't "tighten" a TC.
If it rattles like it has some slack, then you need to change the TC tentioner. (not exactly fun)
Most people just leave it alone as it requires no maintainance
(unless you're over 250K miles)
Old Nov 12, 2008 | 10:44 AM
larso1's Avatar
...although I talked with a auto mechanic (the shop owner) who said don't be too confident about having no problems with timing chains because he's seen several break, not just stretch........ with the resultant catastrophic damage that you would expect with a interference type (valve to piston) engine. Having said that, I personally wouldn't go to the trouble of installing a new timing chain unless of course I had the front chain cover off....then it's just good insurance to replace it.
Old Jan 3, 2009 | 09:58 AM
lalo1963's Avatar
does anyone know how to set the timing chain on a 3.0 maxima I am replacing it
Old Jan 3, 2009 | 10:06 AM
WielkiWaac's Avatar
MaximaDriver
you will have marks on chain and all sprockets
Old Jan 4, 2009 | 04:29 AM
lalo1963's Avatar
timing chain
I see that but there is nothing to guide you say on the back of the timing cover or down on the crankshaft area I see all the marks on the chain and sprockets I have done a bunch of timing belts and chains and all of the one's I have done there is a mark on the block and crankshaft and the camshaft and the timing cover
Old Jan 4, 2009 | 06:57 AM
pmohr's Avatar
No more Maximas...
Did you look at the FSM for instructions? Did you set #1 at TDC before you took the old chain off? Did you search for the info?
Why are you even replacing the chain?
Old Jan 4, 2009 | 09:47 AM
JtzMax's Avatar
Whatchyou say?
Do as Pmohr said ... and hope you're not 180º out.
Read ... Search .... Learn .... Do, then ask questions.
Old Jan 4, 2009 | 10:25 AM
lalo1963's Avatar
timing chain
I had to replace the head gaskets because it was leaking water to the exaust side so since I had to take it off I figure it was smart to change the water pump and the chain and be done with it I did mark it before taking it off but I figure that after installing and turning the chain 4 times around it would come back at the same position I started but it never did
Old Jan 4, 2009 | 10:26 AM
pmohr's Avatar
No more Maximas...
With as many links as there are, you'll be lucky if you ever get all of the marks to line back up.
Old Jan 4, 2009 | 10:38 AM
lalo1963's Avatar
timing chain
thanks after doing a lot of research I kind of figure that thanks again for your input
Old May 18, 2009 | 10:31 AM
blgcx's Avatar
I am working on a 95 with a 3.0 I can hear the timming chain slaping the cover is there a easy way to tighten it?
Old May 18, 2009 | 01:08 PM
pmohr's Avatar
No more Maximas...
Are you sure it's hitting the front cover, and not the guides? The former is rather unlikely.
Is it running the original tensioner, or the updated part per the TSB?
Old May 18, 2009 | 02:36 PM
96MAXIGLE's Avatar
timing chain?
I think this is my timing chain as well...I hear a rattling noise at low rpms...
Old May 19, 2009 | 07:02 AM
BeZerK2112's Avatar
^^^ Yep. However if you haven't changed your water pump in a long time You should to it at the same time, as you have to access the TC tension to get it out. Mine makes the rattle and I know it's the timing chain because it makes the same noise for about 10 minutes after you replace it, but worse!
maxinout93
Oct 27, 2015 01:29 PM
max_speed97
Aug 26, 2015 07:46 PM
doobadoo
Aug 15, 2015 06:43 PM
wingnut2006
Aug 15, 2015 04:16 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
