what was on it before?
the ride difference/acceptablity will be relative to what you've been used to.
i'm running 235/45/18s which replaced my stock rims with 225/55/16s.
the ride with the shorter sidewall is a bit more harsh but completely acceptable.
Quote:
Yes and No. The 40 isn't the actual size of the sidewall, it's the aspect ratio. That is the ratio of the rim diameter to tire width. So if the rim diameter stays fixed, as the tire gets wider, the aspect ratio must get smaller to keep the close to the same wheel diameter.Originally Posted by J RO 9
aren't tires with a sidewall of 40 and wheel radius of 18 the same height as stock (205-65-15)?
Example:
Stock wheel diameter with wheel and tire is 25.5". A 235/40/18 tire has a total wheel diameter of 25.4". Off by only a tenth of an inch. Say you want something a bit wider...but keep the aspect ratio of 40. So lets use a 265/40/18 tire. Your diameter is now 26.3". It's almost an inch bigger! You would need to lower the aspect ratio, so the more appropriate tire would be a 265/35/18 tire..which has a diameter of 25.3".
So in this case of maximaserg, he's going from a 245/40/18 tire...to a 245/45/18 tire. He's going from a total diameter of 25.7 inches to 26.7 inches. Likely he will deal with rubbing issues.
Hope I explained this right. Easiest way to understand this is to mess with a tire size calculator. The one I use has a visual, and you can see what happens with different sizes.
http://www.miata.net/garage/tirecalc.html
The rubbing depends on what offset you run on the wheels. I had to roll the fenders a little to fit the G35 wheels and R compounds. You will def feel every bump in the road.
had 245/45/17 and it rode like hell, now i have 245/40/18 and it rides like hell upgrade itself, sometimes i think lucifer himself is playing around in my suspension and tires. I can live with the bad ride with the amount of grip i have.
I'm probably going to upgrade to some 225 / 55 / 17 for the front and 225 / 50 / 17 for the rear.
Any input? Thanks.
Any input? Thanks.
when i had my black wheels i had 245/45/18 and it rode pretty good. but handling was awesome like stated above it was like a Ferrari.
im about to upgrade my rims to some m35 18s it came with 245 45 18 from reading here i seen it will rub on bumps has anyone rolled the fenders and did it help at all???? and how about when people are in the back seat did it rub all the time
Quote:
What do you mean sloppy? Whats a good combination then?Originally Posted by whiteSE
like a ship...lol sloppy
