projector fittment in r34's
you think these will fit in the r34's with the halo? and could u get a bixenon hid kit for this projector? i would like to put theses in the low beam of the r34's with a bixenon function so i can put another projector in the high beam as a 3500k with the lexus 9006 capsule for the fog light setup.
http://cgi.ebay.com/ebaymotors/ws/eB...m=370111815529
be careful with the term kit while taking about HID's around here. Your gonna get a bunch of and But those are fog projectors. Go for TL projectors, those are all the rage in retro fittings
They'll fit and they'll give you fairly good output... but don't expect it to be OEM projector quality.
The bulb for those ebay projectors is an H7. The moving bulb bixenon hid kits, are designed to work w/halogen reflectors (even though they don't work worth a crap). The bixenon kit moves the bulb in and out to change the focal point on the reflector. If you tried this on the projector... you'd end up w/a really beam pattern.
If you want something w/bixenon capabilities in projector form, and that will fit in the R34's w/minimal cutting. then i'd stick w/a 2.5" projector that takes a d2s bulb....
-look at G37, G35, FX35, e46 bixenon version, LR3, e55, a6. Those are all fairly small.
-The TL, Murano's, Porshe's, New 350z (08) i think are all on the big side.... but do-able. (didn't someone sell a r34 TL retro?)
-Single xenon (non-moving) are RX330, TSX, e46 (Single version), s2000, EVO, SC430, SC460, don't have a high beam function (bixenon)
Edited- Thanks kzoosho
HOPE THESE WORK
just got these and i hope the will fit the r34's if not i hope they fit my oe glass headlights
http://cgi.ebay.com/ebaymotors/ws/eB...m=260315997594
I think you misunderstood. He's saying he wants to use the R34's halogen high beam reflector as a fog light. It's a terrible idea for an ACTUAL fog light, and the clashing colors of 3500k and whatever he ends up using in the projector will look like crap on the ground, but whatever.
i would like to put theses in the (1) low beam of the r34's with a bixenon function so i can put (2)another projector in the high beam as a 3500k (3) with the lexus 9006 capsule for the fog light setup.
I think he wants a yellow foglight beam projector in the "high beam" portion, and a bi-xenon E46 projector in the "low beam" portion.
Don't bother with HID fogs... they'll make it so bright right in front of the car, that you won't be able to see the distance. Just use like ES300 or similar yellow Lexus projector fogs with halogen bulbs.
Im not sure the 9006 capsule would fit inside the projectors.
Im running HIDs in my mini projecotrs and the light is fine with them. I have them aimed lower then my other projectors though.
you my friend have my favorite maxima retro.
how much room is there in the stock housings? I was wondering if it's big enough for two smallish 2.5" projectors to fit side by side. I've only seen one person other than you with dual projectors in stock housings, and they didn't have any clear pictures.
i love the org
u guys are a bigg help. i have been sittin trying to figure out how i want my set up but its hard unless uve seen it before or listen to some one has seen it...i had an image but when i start put all these pieces together i jus like stopped cuz i didnt want to not like it and try with 3 sets of housings that were test fitted .and ive been looking at all the pics of every1s setups but i feel that im ganna end up tryn to many times and end up with some hacked up housings. started the project with some 95 540i halogen projectors then one of my customers wrecked their 07 hse sports and i pulled the projector out of crushed plastic and held on to it and then realized if im ganna take the time it might as well be show worthy like flava and the wizard and all the top notch retroers ... so i guess its time to put in more hours research..i hope i make my mind up once i get these http://cgi.ebay.com/ebaymotors/ws/eB...photohostingin my hands
there isnt much room at all, and I dont really see two 2.5 projectors fitting. I completely hacked up my housing and also used one 2.5 projector and a smaller mini projector. I also cut the car for them to fit.
In all seriousness the only way to learn is to just do lots of research and learn from trial and error.
If yiou can vision it, then you can create it. I had mine all planned out in my head for a while, I then drew everything up and started mocking up templates.
Really? Ive never seen another 4th gen with dual projectors in the OEM housings. Cefiros yes but not the regular OEM styles.
on the little org, two people have them
http://forums.nycmaximas.org/showthread.php?t=13638
it looks like a squeeze though.
I had a pair made by him. That was my first setup.
Hmmm, Ive searched and searched and cannot find any threads with dual retros that are OEM housed. All I found were the typical dual lensed (foglights) and the R34 and Cefiros.I couldnt even find a member named 99blackse.
If you come across it sometime in the future, hit me up. Id like to see his setup and what he used.
Maxima_Joe
11-25-2015 08:19 AM
umnitza
09-01-2015 01:03 PM
