Help with Antenna
Old Nov 23, 2008 | 01:14 PM
Slitfang's Avatar
Help with Antenna
My antenna on my car is broken and im looking to replace it, but i realized AFTER i took it out that i need a bose-compatible replacement. The nissan dealership wants $250 for a stock replacement. Anyone know of another option? btw its almost winter so i need the hole plugged SOON.
Old Nov 23, 2008 | 03:31 PM
pmohr's Avatar
No more Maximas...
Classifieds, junkyards. Have you checked either?
Old Nov 23, 2008 | 03:43 PM
fat_kid's Avatar
which antenna? the mast one or the one on the back window?
Old Nov 23, 2008 | 03:44 PM
djipka's Avatar
antenna is antenna. it doesn't matter if its bose or not
Old Nov 23, 2008 | 03:47 PM
fat_kid's Avatar
there are 2 for some bose systems...
Old Nov 23, 2008 | 04:08 PM
qqqqqqqman's Avatar
Yeah, I've never heard there was a Bose-specific antenna. On a previous Bose-equipped Acura Legend I had, I simply replaced the power antenna with one off of Ebay for $32.
Old Nov 23, 2008 | 04:48 PM
Slitfang's Avatar
well let me clarify, its the antenna mast. And not just any antenna works, you have to be able to plug it into the bose wire from the headunit. As far as junkyards go, im hesitant because everyone i know that has a maxima thats about a 96 has had their antenna go bad.
Old Nov 23, 2008 | 04:54 PM
djipka's Avatar
so if its just the mast there are no cable on it. even if you replace the whole antenna unit you will not have to change the cables that go to the radio so you are fine.
eBay masts are like $15 each
Old Nov 23, 2008 | 04:57 PM
Slitfang's Avatar
theyll connect to the bose cable? also i dont really want another ugly tall mast. I would really like a shorty, maybe from a newer maxima?
Old Nov 23, 2008 | 07:27 PM
BobXX's Avatar
The antenna mast doesn't connect to any cables. It simply has a notched plastic cord going through it that the motor holds on to. The antenna is the same for all 4th gen's, bose or not. I replaced mine with a cheap generic one from eBay and it works fine.
Old Nov 23, 2008 | 10:36 PM
djipka's Avatar
amen to that
Now about the short antenna. You don't even have to have the mast, you know. that's just for AM anyway and I am sure you don't listen to that. I suggest you get a cheap eBay mast and when you install it let it go all the way down and then unplug the power to the antenna so that it stays down. And there is your short one for ya
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
