Battery
Old Nov 30, 2008 | 01:59 PM
maxima-junky's Avatar
Battery
My friends 97 gxe runs and drives fine but if it's left sitting over the weekend the battery is dead upon attempt start up monday morning. Iv'e checked every thing I can think of and there wasn't anything on in the car when I reinstalled charged up batt. Anyone have this exp is so what did it wind up being?
Old Nov 30, 2008 | 02:04 PM
tbergma1's Avatar
I had a friends bmw do the same thing. It turned out to be the glove box light staying on even though it was closed.
Old Nov 30, 2008 | 02:10 PM
maxfever1987's Avatar
search, theres so much on here about batteries, look at the most recent ones goodluck
Old Nov 30, 2008 | 02:20 PM
B_Eaze's Avatar
No corrosion? Whats voltage while cars running? If those are fine, batt is def being drained by something that will most likely be a PIA to find.
Old Nov 30, 2008 | 02:33 PM
its should be 13.5-14.4 some 1 correct me i im wrong
Old Nov 30, 2008 | 10:58 PM
FallenOne's Avatar
While the Vehicle is Ideling, the voltage needs to be at least 13.5, you should be able to turn the blower, and a few other elctronice items on and the voltage still stay about normal.. i had an issue quite recently where my alt went bad, and at Idle with my blower or Any electrical drain whatsoever, my battery would begin to drain, and with its constant drain...
well A new Alternator and battery later.. here i am. :
Old Dec 1, 2008 | 05:22 AM
njmaxseltd's Avatar
How old is the battery? Have it load tested to see if it's starting to fail.
Also measure the parasitic(sp?) drain on the electrical system. If it's high, start looking for the cause by isolating circuits by pulling fuses one at a time.
Old Dec 2, 2008 | 07:08 PM
fixerupper10's Avatar
i would definatly see if maybe something random is left on or hey if it gets driven around sometime during the weekend your alternator could be going out thats going to suck if its that
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
