Front brakes... calipers?
Old Nov 30, 2008 | 03:29 PM
redwagon29's Avatar
Seems like the problems have been never ending...
For a while now my brakes have been squealing so I knew that had something to do with the wear bars. Finally got home for Thanksgiving break to jack the car up and check it out in the garage and the inner pads were completely worn down and the outer were prob 80-90%. So we were thinking it could be the caliper but the brakes don't seem to drag (or if they do they release enough that it is not noticeable). Is that normal for one side to be completely worn down while the outside ones look like new? The inside rotor is a little warped but with the tools at the house we were just able to replace the pads to get it through another month and then I can hopefully get it somewhere to turn the rotors.
Old Nov 30, 2008 | 03:34 PM
maxfever1987's Avatar
both pads on both side shoould have equal wear somethingup with ur calipers
Old Nov 30, 2008 | 06:29 PM
maxx0831's Avatar
check your sliding pins and regrease everything
Old Dec 1, 2008 | 05:28 AM
njmaxseltd's Avatar
Yup, pull the slide pins out, clean and regrease them. Pad should wear evenly.
Old Dec 1, 2008 | 08:04 AM
Fasteddie01's Avatar
If the brakes were squealing, you probably can't continue to use the rotors. They're either worn down too far, or warped from the heat. Better to replace them; you may find some on this site in classifieds.
Old Dec 1, 2008 | 08:18 AM
nafddur's Avatar
Once the rotors are scored (as yours apparently are), just replace them. They are pretty cheap. Once you get the old rotors off to turn them - that is, IF there is enough metal left for them to be turned in the first place - it's just as easy to throw new rotors on. Those could even be the original rotors. I replaced mine for the first time at 158K miles, and they didn't even really need to be replaced (and they only cost $110).
Also, I agree, your calipers are probably fine. The guide pins just need to be lubed up. This really isn't a big problem on a car as old as this.
wyobbagy
Jan 3, 2023 12:03 PM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
Hdnseek
Sep 9, 2015 05:55 AM
beerman1378
Sep 8, 2015 02:19 PM
