Engine braking....
Basically, whenever you aren't putting any sort of load on the engine (well, accelerative force I guess would be the best term for it, though I think I just made that up) you're going to start slowing down (unless you're going down a steep grade).
To clarify... Your actually getting no fuel to the engine when letting off the gas on a 5spd. Try something very interesting:
1-get up to speed... say 30mph (any gear)
2-let off on gas completely
3-turn off the car while coasting... yeah... actually turn it off... and see what happens
4-turn the car back on... (again... while your coasting) as in turn the key to ON (doesn't and will not let you crank)
Very important: All this is done while the car is in motion...
(This only works for a 5spd)
Kinda cool... works with any manual car ive tried...
LOL, I found out in a similar manner, but doing a late-night run on an empty highway, downhill, with a custom high-flow intake on my Altima. It was ingesting so much air it messed up the a/f ratio and just shut off... while I was still in gear coasting. I did what you said, just turned it off then back on and safely pulled over... all w/o a hitch.
Not all. Only the 1995 se and crimson blaze 1999 se-l's had them as a rocker switch on the wheel opposite the cruise control controls.
The 95 had it via hyperhumic constrabulator and the 99 via a flux capacitor.
j/k
j/k
So why do I feel like my car is 'engine braking'. Should I be worried?
i also advise pulling the key out...all the way to make this fully work!
Well, you can only remove the key when it's in the Lock position, right? And that means steering is locked, for autos and 5sp.
Just make sure you're going absolutely straight, that's pretty easy with some caster built in.
interesting, when i let off the throttle in my 5spd jeez it jerks a little then stabilizes itself as it slow down, of course it trys to hold revs at about 1000-1500 but it feels like i stepped on the brakes
LOL @ key out experiment
Ive figured out the key out thing right after i bought the car, its really cool. But i have a question about the ECU cutting fuel. I know it cuts the fuel when you let off the gas, but at wat point does it start firing the injectors again? If I engine brake to like 5mph in first gear the car wont die itl cruise at a steady 5, or idle engine speed in whatever gear im in. So does it fire the injectors once the RPM gets towards the idle speed or before that or wat?
The IPW just drops extremely low, limiting fuel flow from the injector to a very small amount.
Well, I get back in town on Wednesday. I will probably run a compression test then. That is....if its warmer than -15 degrees or whatever it is in Denver right now....
I let the car warm up fully and drove it for 20 minutes or so, unplugged the fuel pump, took all spark plugs out, and cranked it on the starter with the throttle wide open until the readings leveled out.
Here they are in relation to where they are in the engine bay, going left to right looking at it from the front. Or passenger side to drivers side. The arrow points to the front of my car
V
V
V
V
V
4 ... 5..... 6
163 170 171
1... 2..... 3
160 159 168
It held the compression on all these as well, letting it sit 10-15 seconds still held the same pressure. They maybe dropped 1 psi at most.
How do these figures look?
V
V
V
V
V
4 ... 5..... 6
163 170 171
1... 2..... 3
160 159 168
Oh, one more thing to add, my car is definitely shutting off fuel because going down a hill in second gear I lifted my foot off the gas then shut off the ignition and there was absolutely no change in deceleration or engine note.
http://forums.maxima.org/7400-post2.html
142-185 psi.
max difference between highest and lowest is 14psi
you're good for now.
142-185 psi.
i found this thread using the search and hope to get answers here to my issue which seems relevant. When I'm braking and get to almost a complete stop my engine will just cut off. I'm not sure if it's the fuel being cut to the engine. i thought it might be an alternator battery issue but after replacing both this week it still did it yesterday. i have also had the fuel filter replaced. Could it be the injectors? i have over 300K miles on my car. Any help/suggestions are greatly appreciated. Thanx.
The A32 ECU cuts virtually all fuel on decel (not all, but the IPW drops very low).
If I downshift, I'll decel pretty quickly as you'd expect, and the same when it was an auto.
Definitely worth getting a compression test, you really shouldn't be able to push it that easily with it parked in 1st. For the time being, might want to make sure your parking brake will hold it well, or one day it may roll away on you.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Not a good idea at all. Pretty funny though.
