Raced a SC400 and check engine light came on??
Old Nov 13, 2001 | 05:29 PM
Nathan's Avatar
The other day I lined up with a stock '92-'94 SC400 at a red light and we both raced up to 140km/h until we got to the next stop light. I ended up beating him by 1 car length but that's another story
Right after the race ended my Check Engine Soon light came up and it has been 2-3 days now and it is still there. This is not the first time this light has come up and I was wondering what it could be related to? The first time the light came up, it went away in a day or so. I have a JWT pop charger and I think it's causing it. The only other peformance mod I have is an exhaust. Can anyone help me out?
btw, I have a '99
Old Nov 13, 2001 | 05:45 PM
tifosiv122's Avatar
Re: Raced a SC400 and check engine light came on??
btw, I have a '99
If it still has a warantee take it to the dealer...otherwise, do an ecu check...see the stickies above.
Erik
Old Nov 13, 2001 | 05:46 PM
Bags's Avatar
VG Ridah's Biatch Hoe
top of this forum is how to read check engine light and how to reset it
Old Nov 13, 2001 | 06:00 PM
dko's Avatar
dko
duck and cover
try to reset the ECU(on the bottom). if that doesn't work get the code here(top) and decode it here. Once you get the code you can get help here.
Hope that helped you out!
Old Nov 13, 2001 | 08:54 PM
tunedup's Avatar
hey nathan what kind of exhaust do u have ?
where did u get it done and how much?
Old Nov 14, 2001 | 12:10 PM
Blaximazx's Avatar
I bet that one of your O2 sensors bite the dust.
Old Nov 14, 2001 | 02:34 PM
SLC I30t's Avatar
well the lexus drivers have this button on their dash that turns on everyone elses Engine check light...errrr yeah, because that happend to a friend who raced one in a Q45. So thats the ticket.
Old Nov 14, 2001 | 03:03 PM
puremax's Avatar
when the check engine light comes on that usally means the mathmatical equation of the v-6 dohc triple bypass valve double intake cone aqua filter isn't working correctly. you must eat 2 jelly sandwich's with a nice talk glass of vitamen D milk to fix this problem. good day.
Old Nov 14, 2001 | 03:24 PM
Nathan's Avatar
haha, very funny
Old Nov 14, 2001 | 03:27 PM
Nathan's Avatar
Re: hey nathan what kind of exhaust do u have ?
Joee, the exhaust is some generic brand like the ractive intakes but it's a little better quality and comes with a resinator. I payed around $190 including tax, but I later found it elsewhere for $175. I bought the exhaust from Speedtech at Midland and Finch and got it installed at a shop near Warden and Sheppard for $40.
Old Nov 14, 2001 | 03:28 PM
SLC I30t's Avatar
In all seriousness, I don't think the fact that you raced a Lexus has anything to do with your light coming on. So since I have had first hand experience with the ECU thing... check out the stickies above and try to go to the maximadriver.com and go to the "how 2" section to learn to do it yourself.
Tips: the actual stop you turn the screw too is only resistance against the screw... if you keep turning it, it will keep going...this is not good.
Also have the car in the "on" position when doing this...that means you can roll your windows up and down...
Good luck
Old Nov 14, 2001 | 03:52 PM
theblue's Avatar
Nathan, I expect better from you. how do you expect us to help without the check engine code.
Old Nov 14, 2001 | 03:59 PM
tunedup's Avatar
hey nathan
i can give u hand w/ the engine light... ive had to reset it a few times.
I got a shop manual too if u need to look at it
btw. how does ur exhaust sound? was it worth it?
are u gettin annoyed w/ the noise. ?
Old Nov 14, 2001 | 05:24 PM
Justin95SE's Avatar
did you have a place to put that little sensor
sam ekinda thing happened to me. I think there is a little sensor that gets dirty every once in a while. all is better when check engine light goes out though. you know the sensor that went in the stock airbox and now has nowhere to go.
Old Nov 14, 2001 | 05:30 PM
SLC I30t's Avatar
When I put my cone filter on all my sensors had a place to go...
I wouldn't disconnect anything and leave it unconnected... that will set it off for sure.
Old Nov 14, 2001 | 07:49 PM
Nathan's Avatar
Re: did you have a place to put that little sensor
Justin, I haven't yet pulled up the codes yet but when I installed by JWT pop charger on my '99 max, there was nowhere to put the sensor. I'm going to give it a look this weekend. Thanks for the help.
Old Nov 14, 2001 | 07:54 PM
Nathan's Avatar
Re: hey nathan
Joee, thanks for the offer. At the moment, I don't have the extra time to work on it but I might give it a try this weekend and if so I'll let you know.
My exhaust sounds nice and deep not like the civic's in our area with those fart cans. I think the price was worth it because I can either have the resonator on for a stock sound or have it off to turn some heads.
Old Nov 14, 2001 | 07:59 PM
SLC I30t's Avatar
Oh you mean off the scoop? leave the scoop on.
It only does good things... circulates air over there...
Old Nov 15, 2001 | 02:11 AM
tunedup's Avatar
what do u mean
is there something tha screw on like a tip to resonate ?
thnx.
Old Nov 15, 2001 | 07:28 AM
HondaKiller718's Avatar
Re: Re: did you have a place to put that little sensor
That little sensor needs to be connected and tied down somewhere safe. If it's not you get a the engine check light. You also might want to turn you car off then unplug that lonely part and blow on it. (remember blowing into nintendo games in an effort to fix them, same concept here) Then reconnect and follow directions @ maximadriver.com to reset ecu. That should fix your problem. I had the same one with JWT pop charger. (Love that full throttle sound)
Old Nov 15, 2001 | 01:56 PM
Nathan's Avatar
Re: what do u mean
Yeah, the exhaust came with a resonator that screws onto the exhaust tip and quiets the sound to almost stock. It takes like 2 seconds to put it on or take it off.
thnx.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
