oil leak.from..?
Old Dec 10, 2008 | 06:50 PM
Double0Max's Avatar
oil leak.from..?
I changed my water pump back in oct..cahnged oil and what no and in aug i did a full tune up and oil change then also..the weather is now cold..and i have developed a oil leak in the same general area where the water leaks from the pump (front passenger side between block and oil pan) and it is more than just a every now and then drip..its for lke every 10 seconds 4 drops hit the ground..and i smell oil in my heating when i have the heat on in the car..any ideas of why or where it could be leaking from or what seal or gasket as probably worn out..?
Old Dec 10, 2008 | 07:00 PM
CRiME's Avatar
oem ftw!
Sounds like your water pump seals. When mine were failing, oil was leaking from there too (the WP weep hole area), sometimes mixed with coolant. Hasn't happened since i replaced the pump about 2 years ago.
Old Dec 10, 2008 | 07:29 PM
Double0Max's Avatar
but when coolant and oil mix it has kind of a light brownish color to it i think..the oil coming out is still black...but it was a brand new pump the seals can go bad that quick..? if so i am glad i got a lifetime warrenty on the pump
Old Dec 10, 2008 | 07:33 PM
CRiME's Avatar
oem ftw!
My leak was strange - sometimes it'd be just oil like yours, sometimes just coolant, and sometimes a thin, nasty mix I'm not really sure about the longevity of the seals. While anything is possible, it does sound unusual for the leak to present itself so soon after pump replacement. Hang on to the receipt for the pump just in case
Old Dec 10, 2008 | 08:10 PM
vqmaxman's Avatar
Where did you purchase the water pump from was It from Autozone or NAPA ect. I am hearing that the Autozone have crapy cheap kind of water pumps. Napa Is not that great either but It's a little bit better than the Autozone brands.
Old Dec 10, 2008 | 08:29 PM
Double0Max's Avatar
i bought it from oreilly auto parts..i used to work for them we have better parts than autozonce advanced and nappa is our biggest comp between oreilly and napa is about as close to dealerparts you can get
Old Dec 11, 2008 | 05:33 AM
njmaxseltd's Avatar
The water pump doesn't sit in any oil channels.
The timing chain cover is normally what leaks.
Check the water pump access cover, you did have that off when you did the pump??
Old Dec 11, 2008 | 06:26 AM
Turbobink's Avatar
check your rear VC gasket too.
http://forums.maxima.org/4th-generat...t-not-rms.html
Old Dec 11, 2008 | 12:29 PM
Double0Max's Avatar
yea i went thru the access panels on tensioner and for the pump i didnt remove the timing cover.. at first i thought it was my oil pan gasket went bad but it is good.i guess i will try to get her on lift clean and see where it is coming from
Old Dec 12, 2008 | 10:45 AM
Double0Max's Avatar
i will take a look
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
