Climate control?
Old Dec 15, 2008 | 02:59 PM
snowboi1289's Avatar
Climate control?
Awhile back I noticed the climate control doesnt work right at all. Like it doesnt work at 1, 2, 3, but it only works at 4. I figured it may have shorted somewhere on in the climate control fan control, hopefully that is the problem. How do I check, I dont want to simply ruin it, bend something, or even accidentally pull a wire, and cant fix it.
Does anybody have a sulotion, buy that one part, or fix it myself. I would rather try to fix it myself, but I dont know how to pull the thing out. I managed to pull my burnt clock out. I would really hate to buy a hole new climate control thing, because mine is in such good condition, and to have another one that may have acratches on it is not happening in my car.
Any suggestions??
Old Dec 15, 2008 | 03:08 PM
JNCoRacer's Avatar
Just the tip.
You might want to start with the fan control relay located by the blower box under the dash on the passenger side.
Old Dec 15, 2008 | 03:29 PM
Ok. Should it be working at all, because the only level on it works is 4, its not the button kind, its like a ****.
Old Dec 15, 2008 | 03:47 PM
JNCoRacer's Avatar
Just the tip.
Yup. 99% sure you'll find you have a bad relay.
Old Dec 15, 2008 | 06:00 PM
Ok, I'm checkin' right now.
How muc hwill a new relay cost?
Old Dec 15, 2008 | 06:18 PM
Nevermind, I'm ordering one now. Just a question, shouldnt the blower not work at all, if its a bad relay?
Old Dec 15, 2008 | 06:31 PM
alset2's Avatar
no ,because what the "relay" or resistor does is directs different amounts of voltage (less for slower and more for higher fan speeds) . It only works on 4 because at that speed it uses full system voltage, it sorta bypasses the resistor (relay).
Old Dec 15, 2008 | 07:57 PM
Sorry for the noob question, but I see "Blower motor relay" and a "Blower relay", which one do I need. I tried to figure it out, but they seem like the same thing.
Old Dec 15, 2008 | 08:04 PM
JNCoRacer's Avatar
Just the tip.
Same thing.
Old Dec 15, 2008 | 08:42 PM
No, one is cheaper than the other. They sound like the same thing, but I need to know if indeed they really are the same thing, they plug into the same spot, they look the same.
Old Dec 15, 2008 | 08:57 PM
Is this what I need? http://www.autopartsworld.com/Part.a...ling-fan-relay
Old Dec 15, 2008 | 09:08 PM
JNCoRacer's Avatar
Just the tip.
Pretty sure its this one. http://www.autopartsworld.com/1995_n...tor_parts.html
Old Dec 15, 2008 | 09:16 PM
Where does that one go? Like where under the hood.
Old Dec 15, 2008 | 09:20 PM
JNCoRacer's Avatar
Just the tip.
Not under the hood... under the dash. Below/behind the glovebox.
Old Dec 15, 2008 | 09:37 PM
I'll get a mechanic to look at it, because to me, thats alot of money just to spend on how the air conditioner(or in my case, heater, because I havent got a condencer in my car, yet). I'm going to the shop tomarrow to get a vaccum leak check.
Edit: If I do so happen to look at it myself, is there away to tell if its bad or not? What would it look like?
Old Dec 16, 2008 | 04:27 AM
alset2's Avatar
sometimes you can look at it once its out and see it burnt and/or smell it,but its about 99.9% that its the resitor thats bad.its really common in most cars,not just maximas.
also the difference in the two different parts is one is for AUTO climate control and the other is for manual climate control. sorry I dont have time to read all the way to see if you have mentioned what it is.
also ...do it your self ! save some money.its easy and takes like 5 mins.
but if not ,your mechanic really shouldnt cahrge very much at all...if anything.
hope that helps
Old Dec 16, 2008 | 04:55 AM
Feldman's Avatar
Originally Posted by JNCoRacer
resistor FTW
It is a 5 minute job, did mine several months back
Old Dec 16, 2008 | 05:04 AM
fat_kid's Avatar
Originally Posted by bill99gxe
There is a resistor assembly mounted on the air duct close to the blower motor. That part has failed. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved. Replacing the resistor assembly is something the home mechanic can do. The only tool needed is a Phillips screwdriver. The replacement part costs about US$25.
The blower motor is located just above the passenger's feet. Look at the wires leading away from the blower motor. Just inches away from the blower motor there is an electrical connector located on the air duct. That's the resistor assembly. It is easy to remove and replace.
Replacement is the usual remedy. However, if a spot of localized damage is seen it may be repaired with a soldering gun.
There is a good photo of the blower motor and resistor assembly in the Haynes repair manual, page 3-8. If you don't already have a copy of this book, please get one. It will be money well spent.
a) Move the front pass seat all the way back (for convenience)
b) Remove a harness connector (with 4 wires I think) running into the bottom of the blower motor.
c) Remove the 2 philips screws that hold the blower motor resistor in place.
d) Put new one in, reverse install.
Blower Motor Resistor Part Number: 27150-1E405
You can get it here:
http://www.nissanparts.cc/cart/?pn=27150-1E405
Should be $28 at your local dealer. It's $28 delivered from discount Nissan parts sites.
Edit: If you are handy with a soldering iron, you can try to fix it yourself. See this thread.
stickies ftw
Old Dec 16, 2008 | 12:57 PM
Hey, "fat kid", is that what I should get? Thats a really cheap price!!! I knew I seen it somewhere when I was looking through the stickies, but when I just looked through them, I couldnt find it.
Old Dec 16, 2008 | 01:48 PM
Feldman's Avatar
mine from the dealership in town was $22-23 i think. if you go to the dealership and tell them you need the blower resister they will know what you are talking about. this is a pretty common problem with nissans and infinitis. they tried to sell me a new blower too but you dont need it fyi
Old Dec 16, 2008 | 04:13 PM
So I need this part ????? http://www.nissanparts.cc/cart/?pn=27150-1E405
Old Dec 16, 2008 | 06:07 PM
fat_kid's Avatar
thats what it sounds like you need given your description of the problem
Old Dec 16, 2008 | 06:13 PM
Ok, I'm ordering it as I type. I may need to get an account there though.
Old Dec 16, 2008 | 06:21 PM
fat_kid's Avatar
i don't think so, i had to do the same thing but i don't remember if i had to or not
Old Dec 16, 2008 | 06:36 PM
Is the altima one, the same as the maxima one ??
Nevermind, I cancled the altima one, and bought the maxima one.
Old Dec 20, 2008 | 02:42 PM
Ok, I got the part, how do I instal it?? Also, where is it under or by the glove boax ?
Old Dec 20, 2008 | 06:52 PM
any help? Thankis guys for the help, even though nobody has helpede me out, except those people that actually tried to help.
Old Dec 20, 2008 | 07:12 PM
Sorry for the double post, but I need to know this now. I'm fixing to replace it tonight, and I cannot find out how to find the part I need to replce, and replace it. I looked on the net, and in my Maxima book.
Old Dec 20, 2008 | 08:12 PM
Feldman's Avatar
it was under the glove box on my infiniti. i bet it says somewhere in the stickies or you could download the FSM and i am sure it says there
Old Dec 20, 2008 | 08:35 PM
nafddur's Avatar
It's under the glove compartment. You don't have to remove anything to get at it - just take out the two phillips screws and unplug the one electrical connector.
Other than the resistor being in a tight spot (I think I laid backwards and upside down on the passenger side seat to get my head under the dash to see what I was doing), it's one of the easiest things to change on our Maximas. As someone here already said, 5 minutes tops, once you find where it is.
Old Dec 20, 2008 | 10:07 PM
I dont know what FSM it is, like theres so many different letters, I dont understand them all, the only one I understand is fwd.
Edit, Thanks nafddur, I know its under the glove box, but like right or left. I'll figure it out, its very dark out, its really foggy, I have to look up-side down to find it (I dont know where to look for it), and to top it all off, my next door neighbor keeps there stupid *** barking dogs outside, all the time. Bark Bark Bark....
Old Dec 21, 2008 | 12:59 AM
Well, I fixed it. I didnt know it would be out in the open like that. I figured it would be hidden somewhere, but I guess not. It works perfectly now, now alls I need is a condencor.
Thanks to all that helped me out!!!!
Old Dec 23, 2008 | 11:09 PM
yesipuff's Avatar
LOL
Old Jul 6, 2009 | 04:13 PM
ota's Avatar
ota
Very good info, I had the same problem and was considering taking it to a shop where I'm sure they would charge $90 just for a diagnostic and another $200 for the part and install.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
