155k...time for a new clutch but which one
Old Dec 18, 2008 | 06:38 PM
zagato27's Avatar
My 97 SE 5spd has 155k and am noticing a burning smell when I park it. Just had new belts and new radiator hoses installed so don't think they are the problem. I've had the car from 49k to now. Anyway, I remember discussion earlier (tried to search them but no luck) regarding replacing the oem clutch, pressure plate and throw out bearing using the 5th gen parts as these seem to be a bit better. Anybody have any info on this? Point me in the right direction? Especially part numbers as I plan to have this done at the Nissan dealer. Thanks in advance. Cheers
Old Dec 18, 2008 | 06:50 PM
pmohr's Avatar
No more Maximas...
Are you having any sort of problems with the clutch? Slipping, etc?
If not, why do you assume it's the clutch? Seems like a hell of an assumption.
You didn't search, did you?
http://forums.maxima.org/4th-generat...lutch-kit.html
http://forums.maxima.org/4th-generat...lled-nice.html
http://forums.maxima.org/4th-generat...ns-clutch.html
http://forums.maxima.org/4th-generat...-upgrades.html
http://forums.maxima.org/4th-generat...en-clutch.html
http://forums.maxima.org/4th-generat...eded-asap.html
http://forums.maxima.org/4th-generat...lp-please.html
http://forums.maxima.org/4th-generat...questions.html
FWIW the Nissan dealer is going to rape you on price for a clutch install. Why not just go to a regular repair shop?
Old Dec 18, 2008 | 07:06 PM
whiteSE's Avatar
i agree with pmohr. buy the clutch yourself and take the car to a local shop. when i was looking around for some1 to do mine, i was quoted $300 parts and labor...but i went ahead and did it myself.
i recommended a exedy OEM replacement
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
Old Dec 19, 2008 | 03:52 AM
T Keck's Avatar
i just put an exedy oem for a 2000 max into my 97, i just got it back on wednesday so i have only romped on it once because i do wanat to try to be nice and break it in but from th driving ive done so far i love it, i got mine (whole kit) for 140 shiped from a guy on the group deals forums, so i'd recomend him
Old Dec 19, 2008 | 01:01 PM
petro2342's Avatar
How long will my clutch last since it just started to slip in 3 - 5 gear under 80% - WOT? I only have a K&N air filter and do 75% city driving. I don't plan on beating it in this condition.
So a 2000 - 01 stock maxima clutch will be more than enough if I plan on adding y pipe and exhaust while still beating on it once in a while?
Thanks!
Old Dec 19, 2008 | 01:55 PM
1chewabacha1's Avatar
Yeap, 5th gen clutch should be more than enough for an All-Motor setup.
Old Dec 19, 2008 | 04:17 PM
Jesse729's Avatar
I had the same burning smell from my car didn't think it was the clutch but a few days later it started slipping under normal driving. I just had an OEM exedy put in. $146 shipped. I thought about the exedy stage 1 but now that I drove the OEM exedy the stage 1 would have been over kill. The pedal is effortless now with the exedy and it holds strong also.
Old Dec 19, 2008 | 06:25 PM
petro2342's Avatar
Cool, thanks!
Old Jan 24, 2009 | 08:20 PM
(Cody McKown)'s Avatar
I'm in a pickle- soon i'm going to college and looking for random excuses to tell my parents i need a new clutch/ flywheel. i dont know exactly the clutch yet, but i was wondering, with an intake, y pipe, and axle-back, would a 5th gen clutch matched with a fidanza flywheel work out pretty well? i'm all about the 2nd gear chirps. I'm also wondering how much one would cost and install.. thanks.
Old Jan 24, 2009 | 09:06 PM
whiteSE's Avatar
5th gen clutch would be ok....and dont chrip 2nd too often....i blew my diff like tat
Old Jan 24, 2009 | 10:04 PM
10psigti's Avatar
act ftw
Old Jan 25, 2009 | 03:10 AM
97SEdriver's Avatar
this place is dead
I couldn't agree more with the details he's provided
Old Jan 26, 2009 | 07:23 PM
Chirpin 2nd is really that bad for the diff? i guess i wouldnt know why but how else would you shift without spinnin the wheels a bit when shifting? that scares me because i did that a fair amount.. how does the differential have anything to do with hard shifting?
Old Jan 26, 2009 | 08:43 PM
92gxe/cg2's Avatar
You would wait until the RPM's fall from wherever you shifted at to where they're supposed to be in the next gear, then let the clutch out normally, that's how you drive a manual...
Old Jan 26, 2009 | 09:27 PM
pmohr's Avatar
No more Maximas...
When you chirp second you're shocking everything in the trans. If the tires didn't give (spin), then the clutch would, and if the clutch didn't, then you're just shocking the hell out of the trans internals.
That's not to say that you're going to completely blow up your trans if you do it from time to time, but don't go driving around town trying to chirp 2nd and 3rd every single time.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
