Shaking and Vibration
I have a 1998 GXE. I am expriencing some shaking and vibration when I am on the highway. I took the car in, they said the rim was bent, put on a new one. It helped...but didn't cure it. I took it back, said that the tires weren't round, got new ones and now it seems to be worse. I am taking it back in but don't know what to do. I hit a spare tire on the highway and they replaced the stearing knuckle and control arm and it seems to ride fine...just the vibration. Any help...both me and the shop are getting frustrated.
ALOT of maxima's have had this problem. I do everyday on the highway. So does my sisters max. It also feels unstable at 70 which really p!sses me off. I think it's partly b/c the Max's sensitive steering. My car follows road contours way too faithfully.
...and if you think the Maxima's steering is sensitive, try driving almost anything made in Germany. The Maxima actually has one of the least sensitive steering systems I've ever used outside of something large and American.
I have a 97 Maxima GLE and experience this problem on the highway everyday. At speeds of 70+ the car's steering becomes very unstable. Steering shakes like a leaf and becomes worse at higher speeds. I have my tires balanced several times and alignment done 2x and still experience this problem. It could be that I have one or more bad tires (possible radial pulls or separation). However, before buying the car, I read in some reviews that Maximas become unstable at high speeds. I also think that the Maxima doesn't have enough weight to keep it well grounded.
Re: Shaking and Vibration
i had this problem but i knew my rotors were bad so i changed my rotors and front brakes and all the shaking and vibrating went away i have shaking problems whenever my car is moving but i had that problem also when i was using my brakes it would shake a lot ..personally i think my max handles great i love it... 95 max 54k on it....
Interesting about the brakes & rotors...I think my rotors are going to need replacing when I do my brake job...prolly within the next 6 months...but I never attributed that to the shaking in my steering wheel while driving (while stepping on the brakes yes - warped rotors).
My steering shakes between 70 & 80 depending on the part of the freeway I'm on also and I just had the tires balanced (they didn't need to be aligned).
Just 3 letters
AGX
The front strut plays an important role in keeping your wheel planted firmly on the ground. It also is a major part of your front suspension. The lower control arm and the strut are the only 2 things keeping your wheels attached and tightly secured to the car. If the strut piston becomes lose (I'm not just talking about dampening) you get play which in turn will amplify any imperfections in the tire and road.
Since I've installed the AGX's my cars steering is so tight it's like a different car. I never had a shaking problem as many on here report but I can tell you the steering feels much more solid and even bumps are felt much less in my steering.
You've replaced the tires, had the car aligned, checked for wheels which could be bent, put new control arms in. Whats left out in this picture?? The strut!
Re: Re: Just 3 letters
Originally posted by maxnewbie
This may be true, but my car only has 42K on it. Why would it already need new control arms or struts? Or replacing them with new ones will improve the ride despite the mileage?
The AGX's are available at Shox.com Cattman.com just to name a few..
I got the same problem. I've balanced, aligned, tried both sets of wheels tires (stock & 18") no such luck, it still shakes. I do have warped rotors however, I hope that fixes it.
But, I have 78,000 on my car. What do you guys suggest replacing besides Struts. I am going to replace them but since I will have the car apart, I might as well replace whatever else I need.
covers up all i wanted to say..
how are your 18"?
and what kind do you have?
i'm going to get 18" soon
It could be that I have one or more bad tires (possible radial pulls or separation). <snip> my car only has 42K on it.
fyi... My 95 101,000 max drives great on the freeway, I can easily hit 100 mph and ride smooth, well depending on the road. But, I've got H&R's, Tokicos, RSB, fstb, rstb, and bushings. <g> hehe...
hmm, I thought I was the only one with this problem. My car starts to shake when I am doing 60-70 mph on the hwy. I thought this was due to me messing up the suspension system when I went over a bumpy road at a pretty fast speed (I still believe this is the problem). After going through that very bumpy road, I had to change my rims and tires - rims got bent and tires got bumps. Anyway, I went with some really heavy 17" chrome rims, since then I've been told that the shaking is due to the weight of the wheels. Also, the cars starts to vibrate when I am about to make a complete stop at a red light (from 5mph to 0mph.) The vibration is minimal but if felt. Any clues as to why this happens?
1997 maxima gle - 65,000 miles
I had my mechanic adjust my idle screw and I'm fine now.
Originally posted by Sarah99GXE
How is your idle when you are stopped? My car used to vibrate then too...I figured my idle was to low..when I sat at a stop my idle was about 500 rpm and the car shaked as well.
maxima princess? not many have that stat
Need help
23
Oct 2, 2015 08:56 AM
