anti-seize instead of blue goo for brakes?
Old Nov 14, 2001 | 12:54 PM
max808's Avatar
this guy at checkers told me to use anti-seize instead of blue goo for the back of the brake pads. he said it works better and won't melt. any of you tried this?
Old Nov 14, 2001 | 01:27 PM
Curt Deiner's Avatar
Re: anti-seize instead of blue goo for brakes?
Yeah...used it on my F-150. Also noticed Nissan dealer used it on my rear brake job. Between the caliper and the shim.
Old Nov 14, 2001 | 01:54 PM
max808's Avatar
Re: Re: anti-seize instead of blue goo for brakes?
that's good to hear. now we can use the anti-seize for brakes and plugs!
Old Nov 14, 2001 | 02:00 PM
RidinOnChrome's Avatar
i have 2 try that cause since i changed my brakes they dont stop squeeking!!
Old Nov 14, 2001 | 07:50 PM
ericdwong's Avatar
I use anti sieze on the retainer clips. Keeps the pads from "seizing up"...
Old Nov 14, 2001 | 08:25 PM
Synki's Avatar
I orig used anti-seize and all it did for me was make my brakes squeel. The didnt squeel for about the first week but then after, it got terrible. I redid my brakes using this blue jelly looking stuff that i put on the back side of the pads and beween the shims. I forgot the name of that product but you can use CRC Disc Brake Quiet spray. I also put some special coating to the front of the pads to reduce squeel & brake dust. This eliminated all squeels for me. Its been months now since i did this and squeel free. BTW, if you use semi-metallic pads, expect some squeeels. I also only use OEM pads & shims. Replace teh shims if they look groved or worm from teh piston on teh caliper.
Old Nov 14, 2001 | 08:51 PM
TarHeelMax's Avatar
I recently replaced my front brake pads from OEM to Porterfield R-4S pads. I used a new OEM shim kit (41080-40U25) and Permatex Disc Brake Quiet (two small tubes of blue goo). No squealing at all. The Porterfields are a dramatic improvement over stock pads.
Old Nov 15, 2001 | 04:44 PM
now i dont know what to use....all i know is i have squeeky brakes and its annoying!
Old Nov 16, 2001 | 05:25 AM
Did you replace the shims too? I think this may be more important.
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
Stagnet04
Oct 11, 2015 08:16 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
