Door Light killed Window Switch?
Old Dec 28, 2008 | 01:22 PM
Eyce's Avatar
So, about a month ago, I was playing with my Door Light, pulled the bulb out and put another in, and suddenly after moving it around a little, it died. The light would not come on. So, I shrugged and said screw it, I'll take care of it later. I went to lock my door, and the switch would not work. Windows would not go down, auto lock wasnt working. The switch still lit up, but wouldnt operate.
I pulled the door panel off and unplugged the switch, and just let it sit for a while. Came back about 20 minutes later, plugged it back in, and it was operating. I left the door light "harness" unplugged, as it remains today.
Now, I'm thinking about doing some LED mods, but I'm concerned about that switch going out again, or on another door, if I mess with the door lights. I want to LED mod those.
So does anyone know what could have happened to make that switch die like that? I don't want it to happen again, but I really want to plug it back in and LED mod those door lights.
Old Dec 28, 2008 | 01:32 PM
CMax03's Avatar
You oughta check your components ( light and door switch) for wiring tightness/security. But I think the real culprit is the master switch control panel @ the drivers door armrest.
Old Dec 28, 2008 | 02:11 PM
maxfever1987's Avatar
I AGREE WITH ^^^ most def. it has to do with ur door light only thing u were messing with that cuzed ur switch not to work or try checking ur fuses
Old Dec 29, 2008 | 08:33 AM
Speebs's Avatar
I aim to misbehave.
I've had this problem. For some reason the step lights are connected to the window switches (I don't remember if it's driver & passenger or just driver switch that is affected).
When it happened to me I had to get a new switch, because it would randomly stop working and I had no way to put the windows up when it rained. Very strange.
Old Dec 29, 2008 | 11:19 AM
njmaxseltd's Avatar
You tripped the window circuit breaker when you played with the light.
It resets after some time.
Old Dec 30, 2008 | 08:49 AM
Eyce's Avatar
Exactly what happened to me. I was freaking out when it happened to my SECOND switch, so i unplugged it and plugged it back in like I said and it's worked since then. I'm thinking I'll just leave the door lights alone now lol.
doctorpullit
Apr 5, 2017 12:59 PM
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
mpbclutch33
Aug 21, 2015 06:09 AM
kjm900r
Aug 5, 2015 07:14 AM
