annoying noise.. Axel Bearing
Old Dec 29, 2008 | 05:59 AM
kismias7's Avatar
My car is making a constant noise while in gear or out of gear. 5sp obviously. It just started about 2 weeks ago but the noise never stops and does not increase while turning. My brother is a mechanic and took a stethoscope to the axel bearing and said thats my problem.
The whole axel was just replaced within the year. how could it go bad so fast?
Also any idea how much the part costs?
How much labor is involved?
does it require a new half shaft?
Thanks for your help.. its got 153k on it but I want to keep it goin for another year or so.
Old Dec 29, 2008 | 06:28 AM
kismias7's Avatar
please let me know if the axel bearing is a common problem.. tryin to get this fixed this week and just need some advice on it.
Old Dec 29, 2008 | 07:15 AM
Nopike's Avatar
I have a similar problem, started having an annoying grinding like noise after replacing my drivers side half shaft 18 months ago. It's most noticeable at 30 mph and above. I am not sure if the noise is coming from the half shaft or the wheel bearing. I don't believe the axle (half shaft) contains any bearings are you referring to the wheel bearing?
The wheel bearing is a common problem and it is not at all unusual to have one go bad after 150K miles. A wheel bearing is about $60-$70 and labor to change the bearing is $200-$300. You may also need a wheel alignment after the halfshaft or wheel bearing is changed.
Old Dec 29, 2008 | 07:28 AM
pmohr's Avatar
No more Maximas...
Is this only while moving?
So the noise doesn't stop if you clutch in?
Does the noise increase with speed or with RPM?
Old Dec 29, 2008 | 07:58 AM
kismias7's Avatar
noise does not stop with clutch in.
It only makes noise while im moving.
It does change some depending on how fast, not rpm's.
Just had one wheel bearing done and this is a completely different sound. on the axel or half shaft there is a larger round thing, thats where my bro said the bearing is. What is this part? It is on both axels and the noise is coming from the longer axel, right in the circular part.. which i was told is a bearing..
What are the pieces from the axel that can cause this?
I am almost positive its not a wheel bearing.
Old Dec 29, 2008 | 08:09 AM
pmohr's Avatar
No more Maximas...
What 'larger round thing'? The rubber weight in the middle of the shaft? Or the carrier bearing that's only on the passenger side axle?
Old Dec 29, 2008 | 11:21 AM
njmaxseltd's Avatar
Probably the carrier bearing.
Old Dec 29, 2008 | 11:22 AM
pmohr's Avatar
No more Maximas...
Figure the same, but he says it's 'on both axles', so...
Old Dec 29, 2008 | 11:43 AM
kismias7's Avatar
no its the passenger side axel... if i said both axels, i didnt mean to..
What is it like to replace the carrier bearing?
Would i just replace the entire axel?
Not really sure how this work, any help is appreciated. I just know the constant sound is getting to me.
Also my right rear tire locks up when my car sits overnight sometimes.. seized caliper? Ive stopped using my ebrake when I park and it hasn't locked up in a week or so. Each time it locks up I just let it sit and its good by the next day?
Old Dec 29, 2008 | 11:51 AM
pmohr's Avatar
No more Maximas...
First of all, it's axle, not axel.
The bearing itself is on the axle, but I've never heard of one failing or making any noises.
So it hasn't locked up ever since you stopped using the parking brake? It's most likely just a damaged cable, or the caliper itself.
Old Dec 30, 2008 | 06:17 AM
kismias7's Avatar
anyone ever had noise coming from the bearing on the axle?? is this the carrier bearing? Whatever the case, the noise is constant and any help u guys have is appeciataed
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
mpbclutch33
Dec 26, 2015 11:11 AM
Andy29
Sep 29, 2015 05:32 AM
