loose carbon in charcoal canister
Old Dec 31, 2008 | 06:21 PM
Donald199's Avatar
Got the P1445 evap code a while ago, reset ecu replaced gas cap, checked the volume valve, all the hoses and the code came back.
So i decided to take a look at the canister. Before taking it out I decided to knock on it with a wrench and it sounded like its full of sand inside.
Are the carbon inside suppose to be loose or is it simply broken? thanks for the help
Old Dec 31, 2008 | 06:26 PM
maxfever1987's Avatar
maybe this helps u solve ur problem for the code
http://boredmder.com/ecucodes/index....1999&DTC=p1448
Old Dec 31, 2008 | 06:58 PM
Donald199's Avatar
ops it should be 1445 not 1448 :P
Old Dec 31, 2008 | 07:02 PM
depending on the year p1445 is the code for the purge volume control vavle, it is right on top of the intake manifold, it has 2 hose;s coming from it and is a 6 pin connector. veery easy to replace. i can tell u this since i have had to deal with that code and replaced that part to have it fixed good luck.
http://boredmder.com/ecucodes/index....1996&DTC=p1445
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
maxima297
Sep 24, 2015 01:18 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
dcam0326
Sep 7, 2015 07:26 AM
