Well during morning start up and dont know if this is normal but really hard to turn the steering wheel this is also followed buy a ear Piercing screeching sounds of A! belt of i dont know which my first guess power steering belt. It become easy in normal driving so um yall are the guinuess save me lifeee!
well i drive a 5 speed um an no i havent checked the ps fluid lately i had the same issue with my clutch pedal and found out i need fluid but well this fix the squeekin sound too?
Quote:
No, do you use ATF or PS fluid in the power steering system?Originally Posted by Jin Metsuo
Depends on what's wrong, really. If whatever you're using becomes extremely thick in cold temperatures, it could lock up the PS pump for a very short period of time, resulting in your belt screech.
well i dont know i havent changed or checked it yet sence i had the car but when the car warms up to normal conditions ill cut the fan on and then the screachin sound begins then when i cut it off it stop so i dont think it could be the ps fluid but for the recored where is the location of the powersteering fluid?
Quote:
Yes, that would be your power steering belt screeching. Check to make sure it's tight and not glazed over. If it's glazed or cracked, replace it.Originally Posted by Jin Metsuo
Quote:
Well is it when you turn the blower motor on, or when you turn the steering wheel?Originally Posted by Jin Metsuo
If it's when you turn on AC or the defroster, then it's your AC compressor.
ill check the belt as for the blower motor imagine your at a light and then you cut the fan on i.e blower motor...belt sounds off cut, cut off sounds off and and morning start ups.So if its the power steering belt how hard is it to fix myself,if its sc compressor then how do i fix that..thxs
Quote:
Wait, do what? That sentence didn't make any sense.Originally Posted by Jin Metsuo
