broken tensioner on ac and alternator belt.
Old Jan 20, 2009 | 09:59 AM
enik23's Avatar
i turn the bolt and notthing happens the belt does not come loose ive checkd auto part stores and no one has the tensioner itself they all tell me to just get the pulley are they right??
Old Jan 20, 2009 | 10:00 AM
pmohr's Avatar
No more Maximas...
Did you loosen the nut on the pulley first?
And no, if the bolt is broken you'd need those parts, not just the pulley.
Old Jan 20, 2009 | 12:48 PM
Phaedrus220's Avatar
100 posts/7 years - woot!
welcome to a little place I like to call hell. It sounds like you've stripped the top tensioner already, which many of us have done/seen.
That part ages and weathers badly. IMHO, you will want to replace the entire pulley assembly, it's not that costly, (50ish iirc)and the ease of adjusting a new pulley far outweighs fighting the old one.
many posts on this, search.
Old Jan 20, 2009 | 01:43 PM
enik23's Avatar
i just tried to loosen the belt tension by turning that bolt however when i do so notthing happens. the tension of the belt stays the same. Do i need a new puley assembly and where may i get one b\c none of the auto parts stores have it.
Old Jan 20, 2009 | 01:44 PM
pmohr's Avatar
No more Maximas...
You didn't read my response.
Old Jan 20, 2009 | 01:53 PM
enik23's Avatar
oh no i did not.
Old Jan 20, 2009 | 01:55 PM
pmohr's Avatar
No more Maximas...
oh no i did not.
Research before you go turning random bolts, or you're going to break a lot of stuff.
Old Jan 20, 2009 | 02:11 PM
enik23's Avatar
so does that mean ima need new pully assembly or just that the bolt did notthing simply because i didnt loosen the bolts shown in the diagram?
Old Jan 20, 2009 | 02:22 PM
ImmaSquashYou's Avatar
it means...do as the diagram says..if it doesn't work....come back for more help
Old Jan 20, 2009 | 02:23 PM
pmohr's Avatar
No more Maximas...
They're getting worse and worse...
enik23's Avatar
im still having a lill difficulty understanding exacly what bolt to turn before i can touch the belt tensioner pully bolt
Old Jan 20, 2009 | 02:41 PM
pmohr's Avatar
No more Maximas...
The nut. On the pulley.
Follow the diagram. It's got nice little arrows and text and everything.
Old Jan 20, 2009 | 06:57 PM
guygti22's Avatar
its a weird setup. i had same problem. you loosen the actual center nut on the pulley wheel and then raise or lower it. doesnt make since to me either. i took my whole assembly off cause it did that and pissed me off. just loosen the center nut on pulley about one or two turns and then raise or lower the pulley assembly. it works! just weird. most cars you dont touch the nut in the center of the pulley.
guygti22's Avatar
i even took hammer to mine after soaking it in wd40. after that i ripped the whole thing off the block and took it apart. lol
Old Jan 20, 2009 | 07:55 PM
fishforlife2007's Avatar
mine has broke once before....snapped off flush in the top piece as i was finishing up changing out my alternator...needless to say, i was pissed. replaced it and i havent had any problems since. and like pmohr is sayin, if you do your research on a repair before you dive rite into it, you will not break as much stuff if any.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
