Custom exhaust Question. Butt weld or overlap? Opinions/Experience?
I'll be undergoing my custom exhaust work as soon as my Y pipe arrives.
My question to anyone here with experience in their exhausts:
Should the joints be 'butt welded' or 'overlapped'?
The Pro's and Con's seem obious, but I am new to this particular experience so feel free to correct or inform if any of the info I've gathered seems incorrect!
Butt weld:
Pros --> Less restrictive if cut at proper angle and welded correctly
--> Less material (spread ends, overlap pieces, etc.) as such cheaper
Cons --> More difficult to master
--> Less strength
--> Higher possibility of burn through when welding
Overlap:
Pros --> Higher strength
--> Easier to weld and fit
--> Leaves more room for error in cuts
Cons --> Restrictive due to differing sizes and edges, etc.
--> Cosmetically displeasing (more of an IMO)
Like I said, please post what you think! My biggest concern... if I perform butt welds, will they crack on me? My welds will be performed by a experienced welder, and the cuts, I assure you will be precise to within a 16th, I'm taking my time on this one to make sure it's perfect.
For reference, I'll be using 2.5" SS pipe, SS TIG welding sticks, 3/8" steel flanges in stock locations, and all the OE mounting locations.
Thanks in advance for your thoughts/opinions!
Matt
Butt weld:
--> Less strength
Overlap:
Matt
Apr 16, 2020 05:15 AM
