Aftermarket Cams and idle ignition timing
Old Jan 28, 2009 | 12:32 AM
whlimi's Avatar
Hey guys,
I want to clarify something. I'm running nismo knockoff cams and I've been forced to raise my idle to about 850RPM at idle in D and it's around 1000RPM in P. If I leave the idle at 650 RPM in P which is stock, the car shakes like crazy and timing fluctuates between 7-20*.
As of now, my ignition timing is at 6* in P with the idle at 1000 RPM. I know the ECU will adjust timing to get the idle down but I wanted to know how much of an effect directly or indirectly( idle adjustments) a big valve overlap has on ignition timing on our cars. Has anyone been able to retain the 15* advance at idle with bigger cams?
Old Jan 28, 2009 | 06:52 AM
Coolsaber57's Avatar
Might wanna put this question in the All Motor forum, you'll get a better response there.
kjlouis
Nov 24, 2018 06:09 AM
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
95naSTA
Aug 16, 2015 05:03 PM
PhalC1
Aug 5, 2015 02:36 PM
