Replaced starter, now engine dies
Old Feb 3, 2009 | 03:38 AM
Goofball's Avatar
I replaced my starter last night. My car started fine, but I didn't test drive it. On my way to work this morning, the engine just quit. Luckily I could coast to a side street. The engine restarted fine, but quits about 3 seconds after I shift into drive. I noticed that the "Service engine soon" light is on now. It wasn't on before I replaced the starter.
Could I have missed connecting something together that would cause the engine to die?
Old Feb 3, 2009 | 03:46 AM
fflint_18's Avatar
You may have bumped a sensor while changing the starter. Check both the Crank Position Sensor and the Cam Position Sensor for loose connections.
I had this problem with the Crank Position Sensor on another car. It would start, but not run above idle. After awhile it wouldn't start at all. A wire on the CPS had worn thru and was shorting out.
Old Feb 3, 2009 | 03:57 AM
Goofball's Avatar
I'll do a search for their locations. I had to walk 20 minutes back to my house. I'll wait til the sun comes up and go back.
Old Feb 3, 2009 | 06:00 AM
Goofball's Avatar
In the light, I could see I didn't connect something I disconnected. It is fixed.
Old Feb 3, 2009 | 02:40 PM
fflint_18's Avatar
Good Stuff.
Old Feb 3, 2009 | 03:14 PM
wxm's Avatar
wxm
Did you ever find out what was it?
Old Feb 6, 2009 | 03:35 PM
chris2989's Avatar
i changed the started and my alternator because alternator died and the new one i had died as well so i decided to buy another alternator and a new starter and it works good so im guessing try to see if it was your alternator that died and not your engine because those things happen
Old Feb 6, 2009 | 03:43 PM
pmohr's Avatar
No more Maximas...
He already said that he left something disconnected, and that was the problem.
Old Feb 6, 2009 | 07:05 PM
firemax95's Avatar
I' not trying to be a [expletive], but punctuate much?
Old Feb 7, 2009 | 09:15 AM
maxfever1987's Avatar
Not trying to be a [expletive]?? wat is this english class that punctuation matters to you so much?? or r u trying to get ur 15??
Old Feb 7, 2009 | 10:39 AM
pmohr's Avatar
No more Maximas...
He wasn't even talking to you.
Point being, if you actually take the time to punctuate and spell properly (none of this 'wat' 'r' 'u' 'ur' crap), your message gets across a lot clearer. That, and people don't think you're an idiot.
Old Feb 7, 2009 | 02:18 PM
WAS I TALKING TO YOU?? and ur saying this, the one who loves to pick on almost every member here?? and if u write "ur" instead of "your" its easier looks like u dont text message much just take it ez man nothing personal here
Old Feb 7, 2009 | 02:38 PM
pmohr's Avatar
No more Maximas...
I text quite a bit, and yet I still somehow manage to spell words correctly
Old Feb 7, 2009 | 03:23 PM
HomerMAC's Avatar
Donating i30 Owner
.... so yeaaa.... you fixed the problem huh? thats good... also another thing to check in the future for anyone else reading this is the MAF... if you dont plug it in same thing happens.. its easy to overlook these things..
ANYHOW enjoy the car...
p.s. the huamn brian can undretsnd wrods taht anrt wrttien porpprely lnog as the frist and lsat ltter are in the porpper plcae.
... well most human brains.. not everyone is the same... = )
Old Feb 7, 2009 | 09:26 PM
firemax95's Avatar
The reason i like punctuation is because if you don't use it, your sentence makes my head hurt. Obviously I'm not trying to get my 15 posts in since I would have done that back in April of 2006 when I joined.
As for Pmohr,
And as for HomerMAC, you are correct about the human brain being able to do that. However, that trick can only work if the full word is there.
CorollaULEV
30
Aug 9, 2021 08:11 PM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
Samedi
Aug 13, 2015 04:05 PM
