Half-and-Half Intake Setup
Tatanko's Intake Thread
Seeing as I searched and came up with nothing, I figured I would ask before attempting myself. Has anyone done a half-factory/half-aftermarket intake setup? Specifically I mean an aftermarket straight mid-pipe but a factory air box and snorkel. Seeing as I'm a 5-speed, I don't need the extra 5 WTQ down low you lose from the stock mid-pipe and rather than totally compromise the performance and easy-to-maintain setup of the stock intake, I figured I would try this combination. It should yield a good sound (but not TOO loud) and maybe even a wee bit of top end.
Basically I'm wondering if it's even possible. I know the stock intake sort of has a bend in it (which is why the stock mid-pipe has ends that aren't straight from one to another). I suppose I could make my own mid-pipe by ordering a 45 degree angle pipe and adding my own ports for IACV, crankcase breather, etc.
Seeing as how I want to dyno again in the spring (potentially with some sort of tuning device) I would love to compare this to a factory intake with back-to-back runs.
EDIT: Does anyone remember which part of the A32 intake setup has a smaller end on it than the rest of the system? I know when you order a PR-style CAI you get three couplers, all 3", except one has a reduced end on one side to fit either the MAF or the throttlebody or something. Anyone remember which one? (I have a hunch it's the throttlebody).
ricer
lol, um to the actual thread, i think just picking up an aftermarket extension pipe and doing some minor drilling/fabbing will do. pep boys for example has lots of them (mostly plastic, if not all). of course, first measure to see how much distance it is from the end of the airbox to the TB. then get the appropriate size and add couplers to help out. and i think the smaller end of the coupler is for the TB, not positive but pretty sure.
or maybe those aftermarket cai midpipes will reach.
I had already thought about using one of the aftermarket mid-pipes (seeing as I have one laying around) but they won't work I don't think. I say this because if you take notice to what I said in my first post, the stock intake setup has a bend in it in the form of the two ends of the factory mid-pipe sticking out in different directions (as opposed to being straight). See here:
The airbox and MAF are sort of horizontal in the engine bay whereas the mid-pipe and accordion section are at about a 45 degree angle (due to the location of the throttlebody).
That's what I'm thinking of doing. Perhaps one like this:
http://www.siliconeintakes.com/produ...c5ce1c87a7083c
Since the bend of the intake isn't "centered" so to speak between the throttlebody and MAF, I would simply have to trim an inch or so off one end of that adapter and it should otherwise be long enough to reach from the throttlebody to the MAF. My only other concern is engine rotation. Seeing as I have stock mounts, my engine is going to move around a bit. The stock airbox is bolted into place, hence the accordion section to allow for movement. If I put on this coupler, there will be no room for movement. I'm just thinking about what negative effects there might be on the equipment from having to endure that.
TB to mid pipe is a 3" to 2.5" reducer.
Mid pipe to MAF is a 3" coupler.
Im pretty sure the mid pipe only has been done. I'd think the bent mid pipe would work,
unless they aren't long enough. Is your mid pipe bent?
As for movement loosen the bolts on the air box or remove them. I haven't had my box bolted in since '04.
My mid-pipe is not bent. I think it's only Injen intakes that have a bent mid-pipe. Which end is the 2.5" part of the equation? The throttlebody or the mid-pipe? Also, do you not have any added noises from the airbox getting bumped around in the engine bay without it bolted down?
Since I don't have a bent mid-pipe and don't want to over pay out my *** for a new or used Injen, I suppose I need to fabricate one. Simple enough task.
I have a half and half setup. But opposite of what you are looking for. I found this to the best setup after trying stock, full cai, and hybrid. Sticking with the hybrid. Dont mind the dirt, lol.
http://i35.tinypic.com/warmaf.jpg
My setup is mostly OE and partly OSCAI. The pipe that goes downward just after the snorkle, heads into the box under the battery tray. The box has been removed and that pipe has been extended on through the inner fender wall into the area where a true CAI sits. I now have two sources of cold air coming into my completely stock intake.
Here's a pic of the setup as seen when you open my hood. LOL
I kinda have the reverse lol.
I have the stock 5th Gen intake snorkel (I used to have a full 5th Gen setup back when I had an 00VI) feeding the engine bay with cool air (hopefully lol).
Then I have a cone filter, MAF adapter, MAF, stock 4th Gen. resonator (I think that's what it is) with all of it's hoses connected and then the TB.
Under load it has a very nice growl, but under idle or cruising it's not detectable. I do feel like it pulls a tad bit more when it gets loud (3.5krpm to almost redline)
Pics:
Pics:
Could be a while, if ever. Looking at the costs to do this (seeing as it will likely need custom parts) kind of almost makes me wonder if it's worth the trouble. If I end up keeping the engine mostly stock I'll definitely do it, but as of this moment I'm attempting to keep my options open.
Pics:
[IMG] Pictars
Pics:
[IMG] Pictars
No sir.
I've had stock exhaust, stock intake, after market exhaust, 5th Gen intake, 00VI, stock fed. spec. exhaust (I'm cali). I've felt my car in different 'forms'.
I can honestly say that when it starts to really suck air, the car does become more peppy. Typically it's around 4.5k. It gets loud at 3.5k.
Sutter, I think that may be what I need. That slight bend in it there on the one end might be enough for me to use it in combination with the accordion tube and a coupler.
that's about what i have^^^
but i have done mods on friends car where all i have done is swapped out the stock air box for a high flow filter, on a friends frontier all we had to do was saw off is stock air box after the maf and slap on an aftermarket filter
For the record for the rest of this thread, I've been through a million different intake setups myself and don't really need advice on how to hook up a short ram. I just wanted to know if anyone had done the setup I initially asked about and am currently seeking ways to accomplish it (cheaply). That is all. I hope I didn't offend anyone, I just want this to stay on topic.
Pics:
Pics:
I've Also had several different intake setups including the half and half that your speaking of. I ran an Ebay midpipe with the stock box. iirc it was a tight fit but it seemed to work fine...i used that setup for about two months. I'm running a Franken mid-pipe now with a heat shield that i made and a cool air source from the fender.
I looked for pictures of my old setup but could not find any. If i can get a hold of my brother he is running a mid pipe with the stock box on his Max and I'll see if he can submit some pictures for us
Edit: I read your were worried about the engine or box not being able to move around when driving and such due to engine position and i never had any issues with that
This is my current setup if any of you were interested...not really half stock but half cold air half warm air...ill try to get a better picture of the cool air source later tonight
