View Poll Results: does your car whine?
not at all
25.00%
in 1st
62.50%
some other gears
12.50%
Voters: 32. You may not vote on this poll
anybodys elses 5 speed whining in 1st?
Old Feb 11, 2009 | 08:53 PM
whiteSE's Avatar
hey guy. i got my car with 97k a year ago, and my 1st gear whined....evently i blew my tranny up, put in a tranny from a 99 and it whines in 1st as well.....anyone else have this problem?
Old Feb 11, 2009 | 09:00 PM
pmohr's Avatar
No more Maximas...
Make any noise at idle?
Old Feb 11, 2009 | 09:01 PM
R33GXE's Avatar
I think its a pretty common and natural thing I think. Mine has always done it.
Old Feb 11, 2009 | 09:15 PM
whiteSE's Avatar
no. idle is all good. only 1st
Old Feb 12, 2009 | 05:56 AM
Xfactor22's Avatar
if th idle is fine, i wouldnt worry about it. my 99 whines in first but i think it is supposed to, to a point.
Old Feb 12, 2009 | 12:00 PM
whiteSE's Avatar
but its annoying. but seeing that a couple people have that problem, i guess i can live with it
Old Feb 12, 2009 | 01:09 PM
99superblackmax's Avatar
ya mine does not whine in 1st. I wouldn't worry about it
Old Feb 12, 2009 | 02:15 PM
Max_Out's Avatar
Under the radar
Mine is quite.
Old Feb 12, 2009 | 04:43 PM
mastere954's Avatar
mine has always done it, before i blew the tranny and even now with a fully rebuilt one. its not loud at all though but i know exactly what ur talking about. perfectly normal
Old Feb 12, 2009 | 06:05 PM
95max327's Avatar
mine doesn't whine at all... but if it starts to then i know what to expect
Old Feb 12, 2009 | 06:25 PM
EEMaxima's Avatar
Whines in 1st, maybe 1/8 as loud in 2nd, completely gone by 3rd. Idles like a Lexus. Smooth, nothing to worry about.
Old Feb 12, 2009 | 07:56 PM
chillin014's Avatar
I replaced all the bearings "rebuilt" the tranny a year or so back and the first gear whine remained. However when it whined in higher gears, like 5th...I knew there was a problem. That was before the rebuild obviously...and I had alot of noise at idle etc.
Old Feb 13, 2009 | 06:20 AM
sicivic89's Avatar
Mine whines too in 1st. And its done it since I bought it over a year ago. Pretty sure its normal.
Old Feb 13, 2009 | 06:31 AM
Niccos89's Avatar
It naturally happens in 1st and reverse, and is common in 5th gear in some cars.
The sound is actually present in all gears, its just easier to hear in high ratio's (1st, reverse), or when little other noise is present (5th + quiet smooth road + low rpms).
Sometimes a bad bearing can produce a whining sound, but it differs alot. Nothing to stress 'bout dude.
Old Feb 13, 2009 | 07:26 AM
Tatanko's Avatar
Bacon Lover
Mine does a little, but it's pretty quiet. I only really notice it if I don't have music on and there isn't a ton of outside noise.
Old Feb 13, 2009 | 02:51 PM
dgeesaman's Avatar
Maintenance Monster
Reverse makes the most whine because it has a straight cut gear in the mesh.
1st sometimes sounds slightly whiny and that's also normal since the tooth overlap is the lowest of the drive gears. I can barely hear it, so I voted "no". Since all gears are the same width in a Maxima, and the teeth get finer as you go up, the overlap ratio improves and they run smoother.
Dave
Old Feb 13, 2009 | 05:41 PM
whiteSE's Avatar
thanks guys.
Old Feb 13, 2009 | 07:12 PM
deadlydreamx's Avatar
Mine doesnt whine. If it does its not noticeable
Old Feb 17, 2009 | 03:07 PM
thegreat1dev's Avatar
exactly what mine does. it's a 1999 SE. it also makes a different type whining noise in reverse at high speed.
captchaos
Mar 15, 2016 12:18 PM
wingnut2006
Sep 19, 2015 06:13 AM
MaxRPM6
Sep 11, 2015 06:56 PM
lux97Max
Sep 11, 2015 01:12 PM
I<3 A32's
Sep 10, 2015 11:07 AM
