95 Maxima with 98 Engine- HELP HELP!!!
Old Feb 16, 2009 | 03:42 PM
K.Hall's Avatar
First and foremost, Hello World!
Alright, while searching craigslist for a used vehicle, I came across an ad with a very reasonable price...Ok, I'm looking at the pics, blah blah, yeah it looks good then I scrolled up and read the description and it reads...
Description:
95 maxima with a 98 motor... car has 143k and the motor has 80k car is not currently running it needs a computer........
Ok, I called the dude up and he said, "yeah I drove the car for about 4 months then It just stopped running and i did an ECU code check and i got the code that it needs a new ECU"...THat right there was fishy cause I never heard of an engine just stop running after months of driving and then getting a code that states the car needs a new ECU..He said the car cranks and whatnot but wont start...I know the typical problems 'engine coolant temp, camshaft position sensor'...
So, MAXIMA.ORG, help me understand something...Is his story logical or do you think the problems deeper then what he states? What could it be? Im no newb, I've owned 5 Maximas so im not a newb, but this story right here is kind of sketchy....plus he wants 500 or B/O....Please Help.
Old Feb 16, 2009 | 05:37 PM
Snypa's Avatar
deeper.
Old Feb 16, 2009 | 05:55 PM
ZaxWhite97Max's Avatar
Is it nice enough to part out and possibly get over 500 bucks. If so I'd buy it. And attempt to figure out the problem. then maybe you can sell it for more.
But 500 dollars and he says it ONLY needs a ecu? Well an ECU is a cheap problem.
So..I'm going to guess Deeper as well.
Old Feb 16, 2009 | 05:59 PM
95MaximaDriver's Avatar
i agree dig a little deeper into the problem..i have a 95 with a 97 motor and its running fine on the 95 ecu..
Old Feb 16, 2009 | 07:00 PM
K.Hall's Avatar
Thanks alot .org..What could be the cause of this? wiring harness failure or....?????
Old Feb 16, 2009 | 11:42 PM
cvsmaxima's Avatar
you could have my problem.. all im saying is buyer beware.. (or at least more carefull) and dont take any sellers info at face value... even if its a mechanic...
http://forums.maxima.org/4th-generat...ont-start.html
Old Feb 17, 2009 | 06:59 AM
njmaxseltd's Avatar
Do a simple compression check on the motor. If all is OK, buy the car. It's probaby just a sensor, an ECU failure is very uncommon. Even if it's an ECU failure, you can pick up a used one for 300 bucks. That puts you in an $800 dollar car, you still win.
Old Feb 17, 2009 | 07:48 AM
K.Hall's Avatar
After reading that article I lost all interest! Im going to just stick to my 98 Maxima..Thank you guys!!
Old Feb 17, 2009 | 08:11 PM
98maxse5spd's Avatar
If you've already got a 98 then you've got all the parts you need to figure out what is wrong with the other car.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
