Any DIY on how to clean the IACV?
Old Feb 20, 2009 | 09:11 PM
porshapower928's Avatar
I have pulled it off my 95 maxima and before I start spraying I was wondering if I should pull anything apart in there and should use only TB cleaner correct? Thanks
Old Feb 20, 2009 | 09:14 PM
Tatanko's Avatar
Bacon Lover
Be sure to take the gold colored cup off (careful with the screws or you will strip them) and clean in there well.
Old Feb 20, 2009 | 09:18 PM
tigersharkdude's Avatar
be sure to unscrew that big gold valve that has a sensor in it, I used an adjustable wrench IDK what size it is
Old Feb 22, 2009 | 06:27 AM
Snypa's Avatar
gold cap.also blow through the little pipe after your done cleaning.
Old Feb 23, 2009 | 06:12 PM
maxfever1987's Avatar
and let it dry well after cleaning and spraying it
Old Feb 23, 2009 | 08:02 PM
snowboi1289's Avatar
This has been explained before. But anyway, use your tooth brush that you use to brush your teeth, or you can use an old one, lol. Make sure its dry, I would wait about an hour or two for it to completely dry, but your can wait as long as you think it takes to dry. Also, before you put it back on the car, clean the connectors, sometimes that can be the reason why the IAVC has a malfunction (sometimes).
Old Feb 23, 2009 | 08:53 PM
I found it much, much easier to remove the IACV bolts first, it makes it so much easier to remove the electrical plugs
Old Feb 24, 2009 | 04:01 PM
pmohr's Avatar
No more Maximas...
You mean vs cleaning it while it's still mounted to the UIM?
Old Feb 24, 2009 | 09:44 PM
Snypa's Avatar
is that even possible^ to clean while still on?
Old Feb 25, 2009 | 08:20 AM
Why would you clean it while it was still on?? I took mine completely off and apart and soaked it in hot soapy water and took my dremel tool and cleaned it off and polished the metal
Old Feb 25, 2009 | 09:12 AM
pmohr's Avatar
No more Maximas...
Above you said it was easier to remove it first, implying that you've tried cleaning it with it still mounted to the UIM.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
