Engine Check Light Code P0500
Old Feb 23, 2009 | 02:22 PM
azianjiu's Avatar
Hey, I have been getting the code P0500 which points to speed sensor malfunction. However, I changed the speed and that didn't fix the code. Then I tried tightening the screws in the speedo and that got rid of it for like 1500 miles. However, the code just came back. My speedo seems to be correct however my idle is sometimes a little bit low. Does anyone know if this could cause a code like this? I am going to try to adjust my idle however I am curious if anyone else has encountered this code and found these symptoms as well. Thanks
Old Feb 23, 2009 | 05:24 PM
pmohr's Avatar
No more Maximas...
An idle issue shouldn't set a P0500, no. Have you tried tightening the speedo screw again? It's possible that it's vibrated loose.
Old Feb 23, 2009 | 05:29 PM
azianjiu's Avatar
hmm so how tight should they be, because my code did go away for a while. I was thinking about going in there again and trying again.
Old Feb 23, 2009 | 05:30 PM
pmohr's Avatar
No more Maximas...
Tight enough to make a good connection. If it's loose, that could be your problem.
Old Jun 16, 2009 | 12:10 PM
brandonS's Avatar
I am having the same problem. The first time I tightened the screws it held for nearly 500 miles, the second time it lasted for barely 100 miles.
Is there a way to get the screws to stick in there?
There is nothing else wrong with my instrument cluster except the CE light kicks on when the screws come loose.
Old Jun 16, 2009 | 12:26 PM
Max-e-MO!'s Avatar
Go to the auto parts store and tell them one word: LOCTIGHT!
It's a thread compound that keeps bolts from loosing up when installed, that (should) stop the problem of the bolt getting loose.
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
