View Poll Results: Should I fix it or scrap it?
Fix it
33.33%
Scrap it
8.33%
Not sure
8.33%
You're an idiot
50.00%
Voters: 12. You may not vote on this poll
1995 Max GLE - 2 error codes - infinite frustration
Old Mar 13, 2009 | 08:04 AM
  #41
JtzMax's Avatar
Whatchyou say?
Originally Posted by locknuts
i belive this is how it works.
The ecu has two diffrent maps one for your normal operation and a safe map for when sensors and what not fail(IE ks) When it doesnt recive a signal from the ks it goes into the safe map(retard timing) to prevent knocking and detontion
pmohr im i kinda hitting it right or am i completly off??
From the FSM: EC-21
"The KS retarded timing systems is designed only for emergencies. The basic ignition timing is programmed within the 'anti-knocking' zone, IF recommended fule is used under dry conditions. The retard system does not operate under normal driving conditions. If engine knocking occurs, the KS monitors the condition. The signal is trasmitted to the ECM (ECCS). The ECM retards the timing to eliminate the knocking condition."
Just thought I'd share .... this needs to be a sticky for anyone with a KS question. lol
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
Maxie40
Sep 14, 2015 11:28 AM
