95 maxima se will not start?
Old Mar 6, 2009 | 09:03 AM
mondonitro's Avatar
Hello, I get codes of 0607,0701.0101,0407. If I read this correct, missfire #2 ,cam position sensor, crankcase position sensor, random misfire. It has been hard starting for awhile , cranks and stutters, now cranks, stutters feels like it wants to start but will not. No smell of gas, have not checked the plugs. It has been running rough for 2 weeks, 95 se 5speed 185,00 miles. new plugs 2 months ago, new starter, alternater, battery within 1.5 years. Any help where to start to diagnose? Any help would be great, thanks! I really don't want to have to tow it to my mechanic, thats like 85 dollars here in chicago.
Old Mar 6, 2009 | 09:06 AM
Bassbreaker's Avatar
your cam position sensor and crankcase position sensor will cause a no start. Take em out, wipe em off, and try again.
Old Mar 10, 2009 | 10:42 AM
mondonitro's Avatar
changed plugs
plugs were fouled changed them, started up, then no start, cleaned sensors, cam and crank, started right up drove about 20 minutes then, no start, cranks tries to fire but no go. Any help? Thanks
Old Mar 10, 2009 | 03:34 PM
pmohr's Avatar
No more Maximas...
Well, any more codes? Have you checked to see if it's not getting spark, or fuel?
Old Mar 10, 2009 | 03:36 PM
ColombianMax's Avatar
I agree on the crank and cam sensors, Not quite sure which one is the one down in between the trans and engine but when I did my clutch on my 95, I tried removing it only to break the damn 10mm bolt holding it so after this, the damn sensor was loose and sometimes when coming to a stop it would move out a bit and stall my car. Now that you have cleaned the sensors, make sure they're secure in their spot.
btw what part of chicago are you near?
Old Mar 12, 2009 | 02:49 PM
mondonitro's Avatar
ok changed cam and both crankshaft sensors, new plugs, I think the # 2 fuel injector is bad, swapped coils and unplugged no change in # 2. Still hard to start, codes still read 0101 and 0407 even after clearing and driving until they pop back up. Could this be a ground issue? Its at a mechanic now and he sounds puzzled too. Runs a bit rough but still spins the tires. I'm in Andersonville. Thanks to all your replys.
Old Mar 12, 2009 | 02:56 PM
pmohr's Avatar
No more Maximas...
So it intermittently won't start and misfires in cylinder 2?
Have you checked the two grounds at the LIM?
Also, I'd try wiggling the engine control harness where it passes by the right strut tower, they're known to fail there.
Old Apr 20, 2009 | 07:16 AM
alg@nemobile.com's Avatar
I am having a simular issue with my 95 will start off ether but injectors won't activate please pm me if anyone could give suggestions
Old Apr 20, 2009 | 08:54 AM
pmohr's Avatar
No more Maximas...
Post in the newbie thread, and give as many details as you can.
Old Apr 21, 2009 | 11:20 AM
chris2989's Avatar
get something long that is made otu of metal and hit the starter with a hammer or something a little hard but not too hard and then try to start it if it starts then most likely u need a new starter
Old Nov 17, 2010 | 09:57 AM
Reasonablelogic's Avatar
I have the same problem, check the sensors.
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
acw
Aug 13, 2015 12:50 AM
halfpol
Aug 5, 2015 08:24 PM
Jcof88
Aug 3, 2015 10:43 PM
