2ND GEAR @ 90MPH
Old Nov 5, 2000 | 07:21 PM
gmax97
I screwed up royally....I was down shifting to 4th gear (I was getting excited about roadkilling an exclipse)from fifth but I got a little jammed up and threw it to 2nd. Anyway I have this anoying ticking sound that might be a lifter and my exhaust sounds like its misfiring a bit. Any suggestions on what it might be and how to fix it?
Old Nov 5, 2000 | 07:30 PM
Daniel B. Martin's Avatar
The consequence of this mis-shift is that you exceeded the RPM redline. Perhaps your engine experienced valve float and one or more valves "kissed" a piston. Make a compression test to evaluate the condition of your engine.
Old Nov 5, 2000 | 08:15 PM
sx7r's Avatar
oh man, one of my friends did that about 6 weeks ago and his car has been in the shop since then. he was racing a Z28 in his max and went from 3rd to 2nd accidently and he let off immediately and pulled into a gas station. after refueling, he started the car and there was a ticking noise and the exhaust smelled like gas. he drove it home and the next day, it wouldn't start. towed it to courtesy nissan and after 3 weeks, they said he spun a bearing connecting the piston to the crankshaft. after the car cooled down, the bearing seized up on the crankshaft keeping it from turning over when trying to start the car. so now he's waiting for the new engine to be installed.
Old Nov 5, 2000 | 08:18 PM
MisterMatt's Avatar
my friend did that in his cord blew out his power steering belt. Had to drive around cranking the steering wheel just to turn.
SEEE YA
Old Nov 5, 2000 | 08:20 PM
sx7r's Avatar
SEEE YA
definitely better than a new engine
Old Nov 5, 2000 | 08:24 PM
thanjp's Avatar
UH-OH!! Listen to daniel.
Old Nov 5, 2000 | 09:13 PM
Vitaly O.'s Avatar
to make you feel beter
I did that before in my max when I first started to drive five speed never did it again and got lucky without having any problems when I down shiftted in to seccond from 3rd instead of 4th my heart droped especialy when I saw that rpm nedel in the 7.5 range I thought I was gona kill my self for doing that but its been about 8 month since than and my baby is ticking just fine
Old Nov 5, 2000 | 10:10 PM
TommyBoiSxty9
No problems with a slushbox
Old Nov 6, 2000 | 01:56 AM
Che's Avatar
Che
yeah man
that can seriously kill your engine.....my homeboy has a 200sx se-r and he did something to the effect of what happened to you.....his engine was all locked up...bent rods, i think,.
Old Nov 6, 2000 | 05:37 AM
BrianV's Avatar
I did that once in my Integra but not to that degree. The ticking is definately valves. Hopefully they just got out of whack and need a simple adjustment. Hopefully you didn't bend them.
The exhaust noise is probably being created by the valves.
Old Nov 6, 2000 | 06:12 AM
gmax97
Thanks for your ideas....
but now I need to know if this would be covered by the warrantee and/or how much this is going to hurt.
Old Nov 6, 2000 | 06:19 AM
sx7r's Avatar
courtesy nissan wouldn't warranty my friend's max cuz they said it wasn't a manufacturing defect, meaning there wasn't anything wrong with the engine to cause that, and it was just a human mistake.
Old Nov 6, 2000 | 06:49 AM
VQ Quick's Avatar
Dude -you must be stronger than I am.
I have tried to downshift at around 75+ into second and the car won't let me. Not sure how you managed it but OUCH! I kinda figured their might be some type of reline protection that kept things like this from happening but I guess not.
Old Nov 6, 2000 | 07:02 AM
Re: Thanks for your ideas....
No. Nissan warrants against defects in material and workmanship. Driver error falls into neither category. This engine damage is no different from body damage you might do by running into a tree. You caused the damage, you pay to fix it. Sorry if this sounds harsh, but those are the facts of life.
... and how much this is going to hurt.
You haven't obtained a clear and specific damage assessment yet. Without knowing what repairs are necessary, it isn't possible to estimate the cost of those repairs.
Old Nov 6, 2000 | 10:36 PM
party_boy's Avatar
i thought the max had a rev limiter...
i thought the max wouldnt let you shift into second at that speed....it locks you out of the gear..then again you may be superhuman and able to push yourself into that gear. oh wells, the name of the racing game $$$.
good luck and pray it just needs an adj.
Old Nov 6, 2000 | 11:06 PM
Vitaly O.'s Avatar
well
when I did that I yanked it pretty hard I was pissed of because I missed that shift before so I really pulled on it so it poped in upps will never shift like that again
Old Nov 6, 2000 | 11:35 PM
Slickismax's Avatar
I've done that a few times! Once, I was in 5th going about 90 and this Civic wanted some, so I threw it down into 2nd instead of 4th...I actually pegged my tach because I was already revving it for a quick launch in 4th...My VQ squealed and actually smelt burnt...I pulled onto the shoulder, sat there for a few seconds, and then went on my way. Luckily nothing had happened. Ever since that time, I make sure that I don't accidentally misshift.
Old Nov 7, 2000 | 04:54 AM
Rit's Avatar
Rit
Take off all your mods, get a nice haircut, and
go to your dealer, and say you have no idea how it happened. And don't post on the BBS about it until the dealer fixes it - for free, and then tell us all about it!
Good luck!
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
