How do you remove the front seats back cushion
How do you remove the front seat cushion back?
When I searched on how to do this and waded through posts that skipped the vitial info
I found one that said you pop the back piece of the seat that is held in my four clips and then unbolt from there? How do I get this back piece of without breaking the clip or the backing board.
This is my donor power seat .. heres the clips but I broke the backing board trying to pry it off and don't want the same thing to happen on the good seat cushions I'm swapping in. Old seats need to go back into Cefiro for when I sell it soon
There is a bolt here that holds the seat on but you can't really reach it .. you can with a spanner but can't get toque on it and would stretch fabric
Bolt is tucked pretty deep in there
I found one that said you pop the back piece of the seat that is held in my four clips and then unbolt from there? How do I get this back piece of without breaking the clip or the backing board.This is my donor power seat .. heres the clips but I broke the backing board trying to pry it off and don't want the same thing to happen on the good seat cushions I'm swapping in. Old seats need to go back into Cefiro for when I sell it soon
The FSM shows how they're assembled, most likely you'd have to either remove the upholstery, or just slide it up to get to the bolts.
See:
http://forums.maxima.org/4th-generat...lling-off.html
http://forums.maxima.org/4th-generat...-question.html
And many more, from actually searching.
The other image shows a good Idea of how to hold your seat covers back in place using 8 inch Cable Ties in a timely manner; I got mine from Wal-Mart and I paid about 12 dollars for 650. You will need to remove the metal rings that hold your seat covers in place and the back panel in the back of the front seats that snaps in from the bottom. !!!!!!!!!!!!!!!CAREFUL!!!!!!!! I said bottom, the upper part has hooks that you do not want to bend.
See:
See:
vingodine
45
May 21, 2016 12:46 PM
kirkhilles
Aug 8, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
