Aftermarket fender
Old Mar 18, 2009 | 11:56 AM
holymoly's Avatar
Aftermarket fender
I have a rusted driver side front fender for a 1998 Max that I received two quotes for "new" fenders.
One was $75 - I was told its the same as OE
and the $45 was from Taiwan.
Can't seem to find a junk yard that has used fenders, but was told fender replacement was better solution than doing a body repair.
Are these fenders worthwhile or just sheet metal junk?
Old Mar 18, 2009 | 02:29 PM
dkillahster's Avatar
well, not to be an ****, put it this way... "you get what you pay for"
sometimes high priced things aren't as good as low priced items, and vice versa, i can tell you now, the taiwan fender is probably sheet metal junk... and what was the 75 dollar fender? from the stealership?
Old Mar 18, 2009 | 02:39 PM
pmohr's Avatar
No more Maximas...
He said OE like, not OE. Extremely doubtful it's from the dealer, considering even Courtesy lists the fenders as over $200.
Old Mar 18, 2009 | 04:28 PM
I had 1 on my '96, no fitment problems at all.
Old Mar 18, 2009 | 04:57 PM
bamboomerang's Avatar
complete hijack . . .
so i found a scrappy max and buddy is letting me rape it before he junks it friday, 30 bucks for a rust free drive side fender.
life simplifying question: do i need to jack up the car/remove the wheel to get it off? the fsm is vague, is it simply a few bolts connected it to the front bumper and some under the hood? Do i need any extensions? I'll have a 20 minute window to grab it and i've never done it.
Old Mar 18, 2009 | 05:00 PM
pmohr's Avatar
No more Maximas...
There are bolts under the hood, connecting it to the front bumper, and bolts right by the door hinges. Take a look at your own car (or just pull the fender off tonight) to get the idea.
Old Mar 18, 2009 | 05:55 PM
maxfever1987's Avatar
theres also 2 bolts underneath holding it in place underneath by where u jack up the car
Old Mar 19, 2009 | 04:58 AM
holymoly's Avatar
So was it solid? I am keeping my car maybe two years and more so it may be worth it.
The other thing to do do a half-assed body work myself every 6 months.
Old Mar 19, 2009 | 06:03 AM
Ringo1965's Avatar
1997 Nissan Maxima SE
www.car-parts.com This may save you from even having to paint it.
Old Mar 19, 2009 | 06:32 AM
holymoly's Avatar
Originally Posted by Ringo1965
http://forums.maxima.org/4th-generat....car-parts.com This may save you from even having to paint it.
Awesome site.
Thanks!
Old Mar 20, 2009 | 06:01 AM
holymoly's Avatar
OK one wreckers is offering $75 for a used one.
Wow, its 40 miles away, mostly highway driving to check and see if it doesn't even have rust on it.
The $45-$75 aftermarket one seems more tempting
Old Mar 20, 2009 | 06:49 AM
It was infact very solid. The only ding I got was when a cab driver hit it, and it still held up pretty well.
I'm sure the dent could have been popped out, but I already had another 1, so I just replaced it.
Old Mar 20, 2009 | 07:38 AM
holymoly's Avatar
Thanks, I'll go with the aftermarket for $45. The other prices quoted were $69 and $75, so its a good deal.
The body shop wants $250 for the job and recommeneds that the driver's door also be painted because the blue colour is metallic so the colours blend for an additional $50. Is that extra blend necessary?
Old Mar 20, 2009 | 07:49 AM
Man $250 seems a bit overpriced to paint a fender. I got my front bumper, fender, and gas tank door painted for $300. I didn't have mine blended even though its metallic. Its not "necessary", but it depends on if you want it to look "perfect" or not.
Old Mar 20, 2009 | 09:20 AM
Gman8990's Avatar
yeah 250 is an awful lot for just painting a fender... make sure you check around
Old Mar 20, 2009 | 09:26 AM
holymoly's Avatar
I will shop around, but hey I'm in Canada, we don't get the great deals you guys down there get.
Old Mar 20, 2009 | 12:39 PM
BLACKonBLACK98's Avatar
Former Vendor
as always, you get what you pay for.
like oem = arftermarket
probably both made in taiwan/korea/etc.
the problem (not a huge one) with aftermarket is they almost always require some fitting. refinish also runs more becuse there is more prep work involved than painting a used, good condition, oem fender.
Old Mar 20, 2009 | 01:01 PM
DBear's Avatar
I found one on car-part.com which worked fine. In fact, it had a few scratches which match the rest of the car...
If you get an aftermarket painted, consider that the paint on the rest of the car has faded, and they may not match. A junkyard replacement will probably have a similar fade.
Old Mar 20, 2009 | 01:11 PM
Surprisingly, mine required no modification. I guess I was lucky.
Old Jul 20, 2009 | 08:00 PM
BEJAY1's Avatar
Conecarver
paint quotes
Anybody finding reasonable paint prices? I found a local importer doing fenders but the painting is killer at $140 per.
http://www.dnhautoparts.com
Our local body shop wants $150 per fender for a straight paint & clearcoat. I'm trying local yards for used but so far everything here in Chitown has the same bottom front rust as mine.
sliptap
Sep 30, 2015 05:57 AM
Garrettz459
Sep 28, 2015 02:50 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Sep 27, 2015 08:37 AM
