need a good mid-priced brake set-up for my 95...
Old Mar 18, 2009 | 08:34 PM
max ride 41's Avatar
as stated, my brakes feel loose and non-responsive and im looking for a good mid-priced set-up for my 95 auto max. fluids good, new pads up front and just passed inspection but they"ll pass at a certain thickness which sometimes i wonder about. i want better response time so i dont have to worry about rear-ending somebody like i almost did today. i did look in stickies and on ebay but dont want to get junker short lived brake set up, thanks>
Old Mar 18, 2009 | 08:41 PM
mastere954's Avatar
dont even get into that. just save up and put together a z32 BBK
Old Mar 18, 2009 | 08:42 PM
xlcrew's Avatar
I’m Back
for the money a set of front brakes from a 6th gen max are great. i just put 2004 max calipers on my buddies 97 last weekend. the only modification to have them fit was to drill out the hole where the bolt passes through to bolt the caliper. other than that it was a very easy unbolt and bolt up process.
as far as pricing i was able to get a set up off of a 2006 max with only 2000 miles on it when it got wrecked and i got the rotors, pads, and calipers for $150.
that's what i would recommend
Old Mar 19, 2009 | 06:47 AM
Snypa's Avatar
z32 BBk
Old Mar 19, 2009 | 06:57 AM
njmaxseltd's Avatar
Brembo Blanks and Wagner Quiet Stop pads - all for under 200 bucks.
Old Mar 19, 2009 | 07:16 AM
Snypa's Avatar
http://forums.maxima.org/4th-generat...-calipers.html
Old Mar 19, 2009 | 07:47 AM
MROTH's Avatar
just my two cents... if you decide to stick with factory brake setup dont get aftermarket pads (at least not Akebono). I have them on my car now with brembo blanks and the pads just bounce around in the calipers. good on brake dust but im over that, id rather have good strong brakes that dont make noise everytime you hit a bump. brembo blanks are workin like a charm ;-)
Old Mar 19, 2009 | 08:35 AM
Nealoc187's Avatar
SLOW
good pads are the only thing you can buy that will help with the situation you are trying to avoid. changing calipers and rotors will do nothing in the quick panic stop situation. pads with good (or better than you have now) initial bite are all that will help.
Old Mar 19, 2009 | 12:09 PM
mastere954's Avatar
i disagree. i drive in miami all the time (crazy drivers) and have had plenty of close calls while having my stock setup with brembo rotors and hawk pads and i used to practically eat rear bumpers for lunch.
ever since i did the bbk upgrade, i have yet to be close to hitting somebody.
my .02
Old Mar 19, 2009 | 12:33 PM
njmaxseltd's Avatar
Thats not your brakes fault, that's the driver's fault.
my .02
You can only stop as fast as your tires will allow you to.
Doesn't matter how big your brakes are once your wheels are locked, you're SOL.
Old Mar 19, 2009 | 05:26 PM
J RO 9's Avatar
brembo blank rotors all around
hawk hps pads all around
stock calipers, paint them black
my .02
i think importrp has the brembos and hawks in the group deal classifieds
Old Mar 19, 2009 | 05:43 PM
thats what i was thinking as well. i cant afford to buy all this new stuff, just want better braking for stop and go traffic. thanks for re-affirming my desicion.
Old Mar 19, 2009 | 08:46 PM
Nealoc187's Avatar
SLOW
my .02
If you're driving such that you require a BBK on the street tht often you'd be spending many a night in jail. BBKs do nothing for the street. Pads and tires are the only things that matter in matters of quick panic/twitch braking. There's no way you will ever create enough heat to require anything more than those unless you are doing 130+ and then hammering the brakes like you're lapping Sebring.
Sounds like your driving habits have changed or your old setup had something wrong with it.
Old Mar 19, 2009 | 08:54 PM
mastere954's Avatar
come to think about it, i didnt have great tires back then. makes sense.
I WITHDRAWL MY OBJECTION!!
Old Mar 20, 2009 | 09:39 AM
Jeff92se's Avatar
I'm needing a caw
If you are running a 13" Cobra rotor bbk, then you are running 17" wheels + and most likely better tires. Thus, this setup SHOULD net you better braking. Especially with the torque arm advantage that the 13" rotors give you.
Old Mar 21, 2009 | 10:38 PM
97Maximus's Avatar
Shift_custom
Agreed.. most ppl forget this.. but theres no sense in spending ridiculous amounts of money on a BBK using cobra rotors and z32 calipers.. when a 6th gen setup will do the same thing for over half the money.. but hey its your money.. just my .02
Old Mar 22, 2009 | 02:13 PM
Oldmanrwa's Avatar
I put the 2005 setup on my 1998. It worked perfectly. Stops on a dime and doesn't overpower the car. Huge difference. All parts are available from any local auto parts store. The only scary part is drilling the caliper mount. It turned out to be easy and no problem. Only do the front as it is all that is necessary.
Matt93SE
May 24, 2019 02:58 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
rbuswell
Nov 17, 2016 04:54 AM
pkfinn
Jan 3, 2016 02:55 PM
homeyclaus
Sep 3, 2015 06:15 PM
