Trans fluid
Old Mar 20, 2009 | 08:21 AM
ik95's Avatar
Trans fluid
ok i did go and read the fluid and stuff forum but have not really got what i needed.
here is the deal i recently had my alignment done because I hit a curb in the snow and it moved my steering a bit. But after I got my car, mechanic told me that the trans pan is covered with fluid, and its getting low on fluid…………………………….I DON’T WANT THEM TO DO IT, I know it will be expensive.
Does anyone have any suggestions???????, I did look under the car and it is bit covered.
Old Mar 20, 2009 | 08:36 AM
pmohr's Avatar
No more Maximas...
Suggestions for...what? How to fill it, what to fill it with, how to fix it...what?
Old Mar 20, 2009 | 08:50 AM
ik95's Avatar
what to fill it with to get it off the low mark... how to fix it.. i saw at autozone you add this formula to 10 quarts of trans fluid, it suppose to fix the leak. would that work you think?>.......... also where does fluid go?
Old Mar 20, 2009 | 09:00 AM
pmohr's Avatar
No more Maximas...
You fill it with ATF. Regular parts store stuff, synthetic. Your call.
You fill it through the dipstick tube.
Don't half *** it, actually fix the leak; don't rely on 'stop leak'.
All of these answers could easily be found through search.
Old Mar 20, 2009 | 09:17 AM
ik95's Avatar
thanks
Old Mar 20, 2009 | 10:15 AM
JtzMax's Avatar
Whatchyou say?
IBTL .... hehehehe
Old Mar 20, 2009 | 05:57 PM
ik95's Avatar
i just found the problem it was a loose hose connected to the pan... is there any signs that i possibly added TOO MUCH TRANS FLUID
Old Mar 20, 2009 | 06:34 PM
sparky1562's Avatar
Uh, check the level again on the dipstick?
I WIN!
FullMetalJakit's Avatar
Check the fluid level with the dipstick, if you added too much drain some of it out...
Old Mar 20, 2009 | 06:35 PM
99NightRiderMAX's Avatar
check the dipstick, and if there is too much then take that line out again and drain until at the right level
Old Mar 20, 2009 | 10:00 PM
loxety's Avatar
Thats a good question.. what are some symptoms that too much fluid has been added? Will there be slow or rough gear changes? What will happen when "too much" has been put in?
Old Mar 20, 2009 | 10:08 PM
pmohr's Avatar
No more Maximas...
Is this assuming that you for whatever reason absolutely refuse to just check the level on the dipstick?
It could cause an issue or two, depending on how much extra there is.
But the problem is easily avoidable by using the correct amount of fluid.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
