EGR Change now whining and still P0403 and now P0105
Hey everyone!
well i am sooo frustrated right now...i changed the EGR valve today and still getting code P0403 and the EGR seems like its whining when i turn the car on. also i now get code P0105
please help!
please help!
Did you reconnect the MAP sensor?
What EGR valve did you replace? The volume control valve, correct?
Did you replace it without first testing it? Have you tested the harness? Tested the new valve?
Sorry for not being clear...only when the engine is running and you can still hear it for like 1/2 sec after. The car is turned off.
I am going to try to get a replacement tomorrow but any reason why the 0105 code would also show up? Where is the best place to make sure that I put all the vacuum hoses the right way? I really appreciate the help...this car is driving me insane and costing me a lot of $$
The MAP code could be from leaving it unplugged, leaving a vacuum line off, a few other things.
See here:
Code: P0105 | Description: Absolute Pressure Sensor
Are you Fed or Cali spec? The vacuum diagrams are a bit different.
See here:
bryants95max
Oct 2, 2015 12:52 PM
JoshG
51
Sep 21, 2015 10:41 PM
