dipping when on stop light
i recently change my spark plugs, but still having a problem.......... whenever i am on the lights sitting on red light my car seems to like choke/ like its going to die.......... any suggestions what i should be looking at to stop this
does it only happen at lights/stop signs while in drive? does it happen in park or neutral? my friend's maxi is going through the same thing but only happens in drive at stop signs and lights...his transmission solenoids are bad =\
90% chance it's just a coil or an injector.
I have the same issue.
Had a P1320 code which had to do with a cylinder 1 misfire. Bought 6 used packs from a 96. Replaced just cylinder 1. Car drove fine for two days. Replaced the other 5 today. Car runs much better, but still tries to die every now and then when at a light or in P, N, or D.
Plugs are new.
No P1320 code thus far, but it still tries to die.
I'll let you know if I find anything or it gets as bad as it did prior to installing the other 5 packs.
Plugs are new.
My ECTS is brand new, coil packs are used from a 96 (supposedly 100% functional), spark plugs have less than 2k on them.
Are you still getting the misfire code after the plugs have been changed?
If so, chances are you have a coil pack s-l-o-w-l-y giving up.
Clean the throttle body and the IACV, that might help with you out a bit.
no more misfire code... im a rookie with engines is there a forum on cleaning the throttle body and IACV you know of
Anyway, here are some DIYs that you could've searched for:
http://www.motorvate.ca/mvp.php/517
http://www.autotalk.com/how-to/nissa...a-1995-99.html
I had this problem just last week. The car wasnt throwing any codes becuase it wasnt happening often enough i guess. It'd only happen in drive or reverse while standing still...the RPM would dip a bit, and then it would catch itself and go back up. it was perfectly fine while driving.
The last coil pack I changed was cyl 3...so i swapped it again, and its been fine since.
Maxima30
Sep 7, 2015 06:13 PM
