valve cover gaskets?
Old Apr 26, 2009 | 02:43 AM
  #81
djipka's Avatar
Its all done. Rear cover has a new gasket so does the UIM. New fuel filter and oil change.
I took it on the freeway tonight and there is something wrong with the cruise control. Everything looks ok under the hood so I got no idea wtf is wrong with it. It had hard time keeping speed, it would down shift and keep high RPM without accelerating. When I tried to bring the speed up with the button on the steering wheel it would not go up at all or if it did it went back down when I let off the button. HELP!
Old Apr 26, 2009 | 02:47 AM
  #82
pmohr's Avatar
No more Maximas...
So it drives fine when under normal throttle, only has cruise issues?
You checked the vac line to the cruise actuator, and made sure the cruise cable was properly in place? Checked that the throttle cam for the cruise cable moves freely?
Old Apr 26, 2009 | 06:47 AM
  #83
Jatan's Avatar
Adjust the cables -- make sure you didnt swap them
Old Apr 26, 2009 | 12:55 PM
  #84
djipka's Avatar
I guess I will have to check that. My friend was the one to put them back on.
@ Pmohr: what is "Checked that the throttle cam for the cruise cable moves freely?" That cam you are talking about? I looked the vacuum hose it seemed fine. I will recheck it when it stops raining.
Old Apr 26, 2009 | 01:08 PM
  #85
pmohr's Avatar
No more Maximas...
This:
Old Apr 26, 2009 | 04:56 PM
  #86
djipka's Avatar
Originally Posted by pmohr
This:
I see. I looked and I don't think they have been swapped. We didn't even undo them from the bracket. What we did is take off the whole bracket and move them out of the way. I have set the tension by hand so that the two cables are equal.
I am still to look at the vacuum hose though.
Old Nov 14, 2009 | 06:12 PM
  #87
SunsetPalms's Avatar
Spark plug seals don't fit
I am trying to put in the spark plug seals I got from felpro (autozone). They don't seem to fit or are too big. Is there a technique to get them in or did I not get the right ones. I bought one from my Nissan dealer to compare but they too appear to be larger than the rings on the Valve cover.
Can somebody tell me how to install these spark plug tube seals?
Old Nov 14, 2009 | 06:17 PM
  #88
Any advice on installing the spark plug tube seals. I got mine from autozone (felpro) and they seem to be too big to fit in the rings of the valve cover.
Old Nov 14, 2009 | 06:44 PM
  #89
Originally Posted by allensteiner21
they must've installed them inside out i got a full felpro set and no issues and only cost me $50.
I got the same felpro set from autozone and they don't seem to fit on the valve cover opening. What do ya mean "installed inside out"? Is there a technique you can describe?
Old Nov 14, 2009 | 10:14 PM
  #90
Kico's Avatar
I think you are trying to put them in from the front of the valve cover. They go in from the inside of the valve cover take the old ones out compare new to old then oil them then press them with seal driver. put in same way they came out that's what I did, I also used felpro
Old Nov 14, 2009 | 10:30 PM
  #91
tosheto's Avatar
It is kind of hard to get the new once in. You have to force them a little. And yes you do install them on the bottom part of the valve covers, not through the top. Just carefully push it in and it will work. good luck
TKHanson
Nov 24, 2018 01:39 AM
jonreidhead
Jan 6, 2016 09:38 AM
knight_yyz
Nov 1, 2015 01:34 PM
tseng1023
Oct 15, 2015 08:30 AM
