Cloth Seats to Leather?
Mar 29, 2009 | 06:52 PM
Sup guys,
I have a 97 maxima w/ cloth seats and I've been wanting to put in leather seats but I don't know which kind. Can I buy any type of leather seats from a 95-99 maxima or does it specifically have to be from a 97 max? Also how do you change the front two seats? Is it difficult?
Mar 29, 2009 | 07:12 PM
They just bolt right in...
Have you actually looked at it yet? It's much easier to do that and actually see than reading it here and trying to visualize it.
4 14mm head bolts for each seat. Takes all of 10 minutes per side, most of that is getting the seats in and out.
Mar 29, 2009 | 07:23 PM
It's really a simple swap, the hardest part is getting the damn track covers to unclip
Mar 29, 2009 | 07:24 PM
Quote: It's really a simple swap, the hardest part is getting the damn track covers to unclip
I got rid of those things years ago.
Well, actually I lost them. I think.
Now that I think about it, I wonder where the hell they went...
Mar 29, 2009 | 07:36 PM
super easy to do, i have taken my seats out so many times,
all you gotta do to get the complete look is to get all four door covers with the leather inserts. that way you cant tell is ever came with cloth
Mar 29, 2009 | 08:27 PM
Yes, as stated, very easy to do.
You would also, to complete the look, need to swap the door panel inserts.
To do this, what you do is rip off the fabric part (just take a screw driver and lightly peel up one edge and then peel the rest). Then, take the leather insert (if you can get them in the color you want) and set them aside the door panel (with the tabs pushing into the panel) to make the marks. Then use a blade or knife of some sort and make some notches in the panel. Insert the leather insert, fold the tabs, and you're done.
Do this with the door panel off the car.
My car was tan cloth. It is now tan heated leather.
Before:
After:
Mar 30, 2009 | 05:02 AM
Can I take leather seats from any model car from 95-99?? How does the wiring work for moving the seats front and back and such?
Mar 30, 2009 | 06:04 AM
Quote: Can I take leather seats from any model car from 95-99?? How does the wiring work for moving the seats front and back and such?
Not any model car, no. That should be a given. Only the A32 Maxima and I30 are direct bolt ins.
Do you not have power seats now? If not, you'll have to check to see if you're prewired for them or not. If not, you'll have to run power to the seats yourself.
Mar 30, 2009 | 06:12 AM
Also, 98-99 seats had side airbags (some of them). If you get them, you obviously won't be able to hook them up unless you get the right computer.
Mar 30, 2009 | 06:21 AM
Quote: Not any model car, no. That should be a given. Only the A32 Maxima and I30 are direct bolt ins.
I thought they were all wired for power seats, but only some for heated seats
I know that mine was driver's side power seat only, but when I did my swap, the passenger side had a plug right under the seat
Mar 30, 2009 | 06:25 AM
My 1999 was pre-wired for power on both sides. I had to add heat myself.
Mar 30, 2009 | 07:13 AM
Quote: I thought they were all wired for power seats, but only some for heated seats
They may very well be
Don't remember offhand, so figured I'd play it safe.
Mar 30, 2009 | 09:12 AM
Gotcha.
OP, in all likelyhood, you will be pre-wired for power seats, but heated seats you'll have to add (I did).
Mar 30, 2009 | 09:17 AM
yeap , i did my swap 2 pretty simple , theres a write up how to get the heated seats wired , the wizard helped me with mine , i know there was a post with pictures in it .
Mar 30, 2009 | 09:20 AM
http://forums.maxima.org/4th-generat...-question.html
Mar 30, 2009 | 12:06 PM
Only my driver seat is powered, nothing else. Will I have to wire anything for power passenger front seats also? How do I remove the seats again? I just unscrew some screws that's it and it comes out along with the bracket??
Mar 30, 2009 | 12:11 PM
Quote: Only my driver seat is powered, nothing else. Will I have to wire anything for power passenger front seats also? How do I remove the seats again? I just unscrew some screws that's it and it comes out along with the bracket??
Did you not read the rest of this thread?
If you're not pre-wired on the passenger side, you'll have to run power yourself. You take out all 4 bolts and the seat comes out.
