lowering the 95 max.. difficulties!
Old Apr 13, 2009 | 11:49 AM
95max327's Avatar
i have gr2 struts and megan racing springs.. its a 1.9front 2.0rear drop what are the dangers in doing this? what should i expect for handling and ride changes besides a rough ride?
95max327's Avatar
also.. will this setup even work!??!
Old Apr 13, 2009 | 01:11 PM
RA030726's Avatar
I'm nutty for Nissans
dont waste your time with those springs. you will have no suspension travel. stick with a 1.5" drop or less. gr-2's are OK with mild drops.
Old Apr 13, 2009 | 01:16 PM
The GR2's should work with those springs, but I definitely wouldn't do it. If you wannt those garbage springs go ahead and try them, but the drop is too aggressive for those struts. They'll blow. Keep the drop mild, 1.5" or less. If you want a more agressive drop you'll need better struts (Illuminas or AGX's).
Old Apr 13, 2009 | 01:22 PM
ImmaSquashYou's Avatar
do you want your care to just "look" good, or do you want it to handle well also?? A lot of people like the illuminas since they hardly every break and are pretty damn durable. But remember that you cannot adjust ride height without a coilover system. search for suspension setups and you'll realize what you like considering if you want to be slammed, get rid of some wheel gap, have a crazy stiff suspension, or whatever you want. I think some people have ran megan springs and are ok with it. Just don't get dropzone.
Old Apr 13, 2009 | 05:06 PM
95max327's Avatar
i just want my car to look good with the 18's and fix my rear struts so it stops bouncing so much!!
Old Apr 13, 2009 | 05:49 PM
allensteiner21's Avatar
when i saw the title i expected "difficulties" with installation, not with SEARCHING: http://forums.maxima.org/4th-generat...g-springs.html
Old Apr 13, 2009 | 06:03 PM
LudaTej's Avatar
so you're basically juss looking for a mild drop and have no concern for handling right??
i would recommend that you get the h&r springs. they'll give you a nice drop (1.4" front, 1.3" rear) and you won't be sacrificing that much comfort either.
an alternative to these are the tein h-tech's. these springs will drop the car slightly more in the front (1.6" front, 1.2" rear).
both are relatively similar in terms of comfort and handling. both springs would also pair nicely with gr-2's or you could get adjustable shocks (such as tokico illumina's or kyb agx's) for even better comfort.
Old Apr 13, 2009 | 06:23 PM
95max327's Avatar
yes.. thank you that was helpful!!
Old Apr 13, 2009 | 07:01 PM
MaxiNone's Avatar
damn, this is one thing i hate about 4G maximas. the "drop" on any spring doesnt go passed 2.2 up front and 2 in the rear. with that on the car it still looks stock height. gr2's are good struts, my brother ran those on his integra with a 2.5in drop up front and 2 somethig on the rear for a year and the sturts are still good.
as for megan springs skip those and get some ksports and call it a day. you'll have enough clearance for 18's and the ride will be a tad rougher than stock. them struts while hold for a good while...
Old Apr 13, 2009 | 09:11 PM
95max327's Avatar
well good looks on the GR2's but springs are a no no i take it.. well thank you guys very much for all the supportive info.. now i just need to sell these megans and buy some new springs!
Old Apr 17, 2009 | 06:24 PM
supamonkey's Avatar
quick question. does 4th gen max springs fit 4th gen i30's? thanks
Old Apr 17, 2009 | 06:58 PM
Yes, they have the exact same suspension. You should have searched.
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
