Steering is still off after 3 alignments...
I took my car and got new tires, and they aligned it. The alignment didn't seem to be any better, so I took it back again. Then, it still wasn't fixed, so I took it back one more time. Well, it's still off really bad now, so did they just do a bad job or there something else wrong here?
Re: Steering is still off after 3 alignments...
a lot of alignment guys don't really drive the cars except up to the front of the store. If the wheel is off but the car goes straight, the wheels are aligned to the body of the car just not to the steering wheel. This would mean (if I understand correctly), that either your tie rod has been bent too far to properly adjust your alignment or that they just didn't straighten the wheel out before doing the correction. I've been told about people having there wheel turned so the were able to re-gain threads on the tie rod ends for adjustment. It's a half ***, cheap way to do it with out replacing the rod ends.
Go to a GOOD alignment place. There are places that do truck alignments and have machines that are able to do such things as caster pushes to get everything into spec. I had the exact same problem as you did and I went to these guys and now my alignment is pretty good.
So how do I know which are GOOD alignment places? I'm trying to sell my car and I need to get this problem fixed soon, so I can get a 5 speed max!
I live in San Diego and I get mine aligned at a place called True Line.
Yeah, definitely go to a place that specialized in alignments and not just another wheel/tire place. They could give a rat's *** in most cases, but specialized alignment places live off of alignments so they usually do a better job. I usually only go to places that I get referred to now after getting screwed over at many places.
Re: Re: Steering is still off after 3 alignments...
Originally posted by 99BLACKMAX
I HAD THE SAME PROBLEM DUE TO A BALD TIRE. I GOT NEW TIRES AND THE STEERING WHEEL WAS STRAIGHT.
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
