changed transmission now wont start....help please
Old Apr 13, 2009 | 08:06 PM
Blackwind's Avatar
ok, i changed my transmission 2 days ago and afterwards i get everything wired up (been 5spd swapped for 6 years now) and i go to turn the key and NOTHING just the lights in the dash and thats it. no chug-chug,nothing. i took the starter to autozone tested good. got some suggestions on how to "hotwire" the starter. starts fine that way.
so now i am at a loss, all fuses are good all connections are tight. battery is charged. i used my parts car (the wifes) to see if it was the ignitiuon switch. nope thats not it. so now i am stumped, anyone have any suggestions? my next option is to make a push button start, so if anyone has any experience in that area i would welcome that advice as well.
thanks.
Old Apr 13, 2009 | 08:18 PM
pmohr's Avatar
No more Maximas...
How exactly do you have the park/neutral sensor wired up?
That's most likely your problem.
Old Apr 13, 2009 | 08:19 PM
f550maranello2's Avatar
how exactly did you hot wire the starter...
check the clutch interlock switch aka park neutral switch... i bet its not hooked up...
Old Apr 13, 2009 | 08:21 PM
Blackwind's Avatar
by way of the swap instructions. its been the same for 6 years do it kinda throws me as to why its not working.
Old Apr 13, 2009 | 08:23 PM
Blackwind's Avatar
wire from positive terminal to solinoid plug, had wife turn the key and voila, it starts.
Old Apr 13, 2009 | 08:25 PM
pmohr's Avatar
No more Maximas...
What you need to do is run a jumper across the P/N connector, see if it starts then.
Likely it's not working now because of a wire mixup, or something else, since you just worked in the area.
Old Apr 13, 2009 | 08:26 PM
just make sure its hooked up and working...
Blackwind's Avatar
you got a pm coming
Old Apr 13, 2009 | 08:29 PM
Blackwind's Avatar
either one of you guys know how to do a push button start?
Old Apr 13, 2009 | 08:34 PM
just use the key... ur dont driving a spaceship..
Old Apr 13, 2009 | 08:36 PM
Blackwind's Avatar
the key aint starting the car. i would use the push button to "kick" the starter. ....spaceship.
pmohr's Avatar
No more Maximas...
IIRC it's in the FAQs, but any remote start 'kit' or button you buy should come with instructions and a wiring diagram.
Old Apr 13, 2009 | 08:39 PM
Blackwind's Avatar
what page? im lookin but drawing a blank.
Old Apr 13, 2009 | 09:48 PM
Blackwind's Avatar
problem solved. i grounded one wire. a wire which i NEVER had to ground before. and it started right up. thanks for the input everyone. it helps to have more than one mind working on a problem.
Old Apr 14, 2009 | 06:54 AM
rroderiques77's Avatar
Demodded and Forgotten
Hey. Just saw your thread regarding this. Glad you got it figured out.
Old Apr 14, 2009 | 07:27 AM
Blackwind's Avatar
im gonna come by the shop in a few. can you plug up my car?
Old Apr 14, 2009 | 10:01 PM
I think it may be ECU time for you..
It turns out TS cannot do reflashes on Saturdays. I am going to end up taking the trip to LA during the week. Probably gonna go on Wednesday or something.
Old Apr 15, 2009 | 01:31 PM
Blackwind's Avatar
what made you come to that one?
Old Apr 15, 2009 | 08:32 PM
let me guess ground wire to trans?
Old Apr 15, 2009 | 08:35 PM
pmohr's Avatar
No more Maximas...
No, P/N harness. You don't need the ground to the trans casing, I took mine off years ago. It also wouldn't cause a no crank situation.
Old Apr 15, 2009 | 09:06 PM
Thats what i meant.. ur right
Old Apr 16, 2009 | 07:31 AM
ProW649's Avatar
I have a question....if anyone can help me please do...I have a 95 Max (VQ30DE) swapped it's an automatic n i wanted to know if a spec v tranny would fit without major complications.
__________________________________________________ __________________
1995 Maxima
VQ30DE swap
Injen Rd series Intake
Old Apr 16, 2009 | 07:36 AM
pmohr's Avatar
No more Maximas...
First, there's a sig for a reason, so you don't have to post your crap in every post you make.
Second, the 6MT in the Spec V? ...no. Not like it is, anyway, unless you make a custom bellhousing adapter for QR-VQ.
You could swap it in from the A33B/A34, if you want a 6MT. Or use the Spec V internals with a VQ bellhousing.
Why not just go with a 5MT? Cheaper, easier, more readily available.
Old Apr 16, 2009 | 10:26 PM
Blackwind's Avatar
yeah apparently the one wire i never touched before would be the one wire i need to make the car run.
thanks for the help again.
Old Jul 14, 2009 | 10:50 PM
CEASE225's Avatar
I HAVE THE SAME PROBLEM, WHICH WIRE DID YOU GROUND??????
Old Jul 14, 2009 | 10:52 PM
pmohr's Avatar
No more Maximas...
Drop the caps, no need to yell.
As he said, the PNP switch harness. There are only two wires there, figure it out.
Old Jul 15, 2009 | 08:58 AM
Blackwind's Avatar
ill look and post later.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
doctorpullit
Jul 20, 2019 09:31 PM
The Wizard
24
Oct 1, 2015 08:47 PM
pjgreek
Sep 9, 2015 09:30 PM
