Heat from engine
Old Nov 21, 2001 | 10:16 PM
TintDaMax's Avatar
Heat from engine
Starting a couple days ago, during longer drives, I can feel the heat coming from the engine. At first its kind of warm, but after about 2 hours, my legs feel like they are on fire! This has never happened before, and I have no idea why it started. Any ideas?
DPW
Old Nov 21, 2001 | 11:02 PM
Nismo's Avatar
maybe you have the air vents on the setting where the air vents blow to the ground. I know that even when I dont have the fan on, I can still feel air blowing through the vents because I have it on the fresh air setting but when I put it in recycle air mode then it stops.
Old Nov 22, 2001 | 09:15 AM
sinewave's Avatar
Maybe a rubber seal or plug in the firewall has fallen out.
Old Nov 22, 2001 | 06:38 PM
lefty
I feel the same thing when I have the temperature set to a high setting...even though the climate control unit is off...it seems to remember the last setting and continue the heat. Then I just turn on the climate control and turn the temparature lower and all is fine.
captchaos
Mar 15, 2016 12:18 PM
seesole
Sep 14, 2015 12:38 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
DayHeyZeus
Sep 11, 2015 03:17 PM
bennuss
Sep 11, 2015 05:55 AM
