remote door lock question.
Old Nov 22, 2001 | 09:04 AM
dcbb
I have a 97 SE stock everything. Neither of my remotes for the alarm, door lock,windows, trunk work. I now have to used the key to enable the alarm lock the doors. is there a fuse that controls that remote? if so where? I doubt that the batteries in both remotes would've gone bad at the same time. Thanks
Old Nov 22, 2001 | 11:11 PM
Dave Holmes's Avatar
Re: remote door lock question.
A search revealed:
This is from http://web2.airmail.net/scutchen/max_faq/
Quoted Message:
Q: How do I reprogram the Keyless Remote?
A: Here's the procedure from the 1995 Factory Shop Manual
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times
within 10 seconds. (The hazard warning lamp will then flash twice.) At
this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if
door is locked using the remote controller during this ID code entry
enable state, a new ID code can be entered). At this time, the new ID
code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the
driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the
driver's door is opened.
NOTE
If you need to activate more than two additional new remote
controllers, repeat the procedure "Additional ID code entry" for each
new remote controller.
If the same ID code that exists in the memory is input, the hazard
warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter
more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be
accepted. Additionally remote control signals will be inhibited when an
ID code has not been entered during the "setting" mode.
REDinLV
Aug 15, 2024 12:30 AM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
