slight vibration
Old Nov 22, 2001 | 09:28 AM
atticdog's Avatar
slight vibration
hello everyone i just got my first maxima 3 weeks aga its a white 99 gxe 5 speed and i love it. one thing i notice is i feel a slight vibration on the highway and gets slittly worse when turning on the highway i think i might need the tires balanced any ideas?
Old Nov 22, 2001 | 09:57 AM
AdMax98's Avatar
That, or a wheel is loose, or your alignment is out.
Congratz on the new purchase!
Old Nov 22, 2001 | 10:36 AM
Synki's Avatar
Could be a few things.
1. Alignment is off
2. Tires are "true" meaing they may have flat spots
3. Rims are bent but wheel weights usually fix that problem
4. Your lug nuts might be loose
Old Nov 22, 2001 | 12:50 PM
99maxi's Avatar
your nuts maybe loose...
Old Nov 22, 2001 | 12:57 PM
max808's Avatar
vibration
i have vibration too, but only when braking and carrying a full load.
Old Nov 22, 2001 | 02:33 PM
atticdog's Avatar
its very slight and in the steering wheel
Old Nov 22, 2001 | 02:38 PM
Synki's Avatar
Re: vibration
Usually when you get vibrations while braking is most likely that your rotors are warped.
Old Nov 22, 2001 | 05:17 PM
KiLIAkLoWn's Avatar
i get a vibration when going about 80mph. Ne reason to be worried?
Old Nov 22, 2001 | 06:14 PM
ny96max's Avatar
i have the same vibration at around 80, but at 90+ it goes away. I think i may have bent something last year. I nailed a spped bump goin 20 and since then its been a lil shaky. Tires are fine and so is alignment.
i just learned to deal with it!
Old Nov 22, 2001 | 06:53 PM
KiLIAkLoWn's Avatar
So if i had a bent rim i would only notice it going 80? What other things would happen if i had a bent rim?
Old Nov 22, 2001 | 08:26 PM
CFster's Avatar
I have the same vibration. My tires are relatively new and we balanced them three times and rotated them to try to cure it. I think I can safely say it's not tires or wheels or balance. The rotors aren't warped either. Now I'm looking at the tie-rod ends...
CFster
Old Nov 23, 2001 | 08:58 AM
KiLIAkLoWn's Avatar
CFster
I have rotated and balanced my tires too. Didn't really think that it was that much of a safty issue. But i'm not much of a car expert.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Bonka
Sep 14, 2015 11:18 PM
