Need input.....noise on the left side of the engine
Old May 9, 2009 | 04:49 PM
sicivic89's Avatar
So a few days ago I started to hear a tiny whining sound coming from the left side(timing cover side) of the engine. My first thought was that I know that my power steering pump with leaking a bit of fluid and that thee bearing was probably going out on it. The sound slowly has gotten louder and more consistent over a few days. Today I go out to the car and start it up and decide to take a look more closely at the belts and pulleys while the car is running. I noticed and smelled the belts were rubbing something. My first thought was the idler pulley was going bad. So I took the idler pulley and the belt off. Then I figured I would start the car up without the belt and idler pulley to see if the noise when away. Well, its still there and I noticed the crank pulley looks to have some wobble. So I'm thinking the noise might actually be a main bearing gone bad which is causing the crank pulley to wobble. Check out the video and let me know what you think.
http://www.youtube.com/watch?v=7lXTdZMcM-o
Old May 9, 2009 | 06:04 PM
pmohr's Avatar
No more Maximas...
Is it just the outer ring of the crank pulley, or the inner as well wobbling around?
If just the outer, no big deal. It's a relatively common problem, just replace the crank pulley. The rubber deteriorates over time.
After that, see if the noise is still there.
Old May 9, 2009 | 06:41 PM
sicivic89's Avatar
Ok, after further investigating, indeed the outer is wobbling and the inner is not. The noise I heard was the outer part of the pulley rubbing the power steering belt. So I need a new crank pulley. Replacing the pulley will require dropping the engine and transmission out of the car, correct?
Old May 9, 2009 | 06:44 PM
pmohr's Avatar
No more Maximas...
Err...no. Why would it?
Remove the PS belt, remove the crank pulley bolt, R&R the pulley, reinstall bolt, reinstall belts.
Old May 9, 2009 | 07:26 PM
sicivic89's Avatar
Ok, excellent! I thought you would have to use air tools to get the crank bolt off, but looks like you can fit a breaker bar in there and do the crank the engine over slightly idea and it will come right off. Thanks for your help!
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
Flores94
Aug 11, 2015 12:53 PM
