rear caliper problem
Old May 18, 2009 | 04:05 PM
shavedmax's Avatar
i think i may have over extended the rear calipers. i tried to turn them back in, and they do spin, but they wont go in. does anyone have any idea what to do to get them back in?
or has anyone had experience rebuilding them? i dont feel like spending 200 bucks on 2 rebuilt ones when the rebuild kit is 8 bucks each.
i tried searching for it but all the threads didnt have a result posted
Old May 19, 2009 | 05:28 AM
Ringo1965's Avatar
1997 Nissan Maxima SE
My first question would be have you opened up the bleeder valve? This will help relieve some of the pressure inside the caliper. (I just went through this myself) Second clockwise in-clockwise out. I hope you are using the cube tool that you can buy (or borrow) from autozone for like $10. This will help you put better even pressure, as you push in and turn. I have even soak my threads before with some P.B. Blaster, and used a air gun to free up a stuck piston before! (I ran that sucker in and out about twenty times before I even hit bottom) Not recommended, but I was in a bind at the time and so far it has worked. Good luck
Old May 19, 2009 | 05:02 PM
shavedmax's Avatar
i have the cube, but it's extended so far that when i spin the cube it hits the caliper and doesnt turn anymore. i was able to get it to spin with pliers, after i spun it a couple of times i tried to use the cube again, but realized that the caliper must be extended too far. i opened the bleeder too to try to release pressure, but it's still too far out. i may take it off and try it on a vise.
Old May 19, 2009 | 09:25 PM
ImmaSquashYou's Avatar
just rent the caliper tool from autozone. Yes, it can keep on spinning and not retract. You have to push and turn hard. Rent the caliper tool, not just the cube and you'll save a lot of trouble. Open the bleeder valve and it'll be even easier.
Old May 20, 2009 | 08:43 AM
Ringo1965's Avatar
http://forums.maxima.org/3rd-generat...+brake+caliper
I thought you might like to read what other members thought
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
