LSD and NON LSD
Old May 20, 2009 | 09:12 AM
022580's Avatar
LSD and NON LSD
Are these transmissions interchangeable ? Do any parts need to be changed in order to go from a LSD to NON LSD ?
any help is greatly appreciated
Old May 20, 2009 | 09:30 AM
pmohr's Avatar
No more Maximas...
...did you search at all?
Seriously, it's a sticky.
http://forums.maxima.org/all-motor/3...swap-info.html
And why would you want to swap to an open diff trans?
Old May 20, 2009 | 09:53 AM
maxboy325's Avatar
Wow. IBTL
Old May 20, 2009 | 11:39 AM
022580's Avatar
yeah is read that.... and im suppose to get a answer from it ? One guy says the passenger one needs to be changed, the next guy says no mine fit fine...
some have the 01 lsd and others have the 4th gen lsd.... ill compare parts with Nissan, it will be much easier.
oh and im changin it cause LSD is next to impossible to find...a rebuild cost 1000-1500, plus labour. Or i go buy a non-lsd for 500 and call it a day.
Its a stock maxima is not going to make or break the performance.... plus its a winter beater its 12 years old.... So i dump mad money into this or save and put the monies towards my ARP stage 3 kit for my S4
I have searched and that is why im asking again,
Old May 20, 2009 | 11:41 AM
pmohr's Avatar
No more Maximas...
Okay, for the obviously search impaired:
The passenger side axle is the same. Everything is the same except for the driver's side axle.
A32/A33 RS5F50V are externally and functionally identical.
Happy?
Old May 20, 2009 | 11:49 AM
022580's Avatar
That was simple.... and have you done the swap yourself ?
Old May 20, 2009 | 11:50 AM
pmohr's Avatar
No more Maximas...
No.
Old May 20, 2009 | 11:55 AM
022580's Avatar
thanks for your help...
if there is anyone who has actually done the swap, not someone whos friend has done it...someone who went threw all the work of removing a tran, and swapping it..
I would appreciate there feedback on this please...
pmohr you are prob 100% correct but tran swap are a pain in the *** and i do not need little obstacles along the way cause im gonna end up smoking 2 packs ...hahah.
Old May 20, 2009 | 12:04 PM
pmohr's Avatar
No more Maximas...
The part numbers are all the same, and it's been demonstrated time and again, but I guess you'll just have to wait for someone to come along that's actually done it
And what's so hard about a trans swap? Takes a couple of hours at most.
Old May 20, 2009 | 06:21 PM
emdot's Avatar
took me 2 hours to do my trans in my friend's driveway with all hand tools on friday.
....then again this is my 4th clutch and 3rd trans so i got it down to a science.
btw, i did the vlsd. there is no difference in labor...get the driver side axle for the corresonding trans and you're good as golden.
btw,
ARP= rod bolts, extended studs, etc
APR= vw/audi tuning
lol sorry had to do it
Old May 21, 2009 | 03:03 AM
dgeesaman's Avatar
Maintenance Monster
Feedback...
You're arrogant and maybe it's better if you have to find the information yourself. This topic is discussed regularly and the question has been answered many times over when asked by less obnoxious people.
Dave
Old May 21, 2009 | 05:03 AM
f550maranello2's Avatar
i have you only need the drivers side axle to change..
ef9
Aug 14, 2015 03:03 PM
Supragte
Aug 12, 2015 10:00 PM
LoveSick
58
Jul 23, 2001 01:36 PM
madmax2k1
25
Jul 9, 2001 03:57 AM
Turbo95Max
Mar 30, 2001 12:35 PM
