Fidanza Flywheel Probs (pics)
Old May 21, 2009 | 11:33 PM
got_max's Avatar
Wants a real car
Hey Org
So heres the problem,
Im just getting close to done with a 5 speed swap, all good so far. I opted to get a Fidanza flywheel with high hopes. I went to put it in and ran into the first problem, the center bore of the flywheel was about 5/100's of and inch to small, and had to almost be pressed onto the crankshaft. I did get it bolted on and tourqued to spec but stupidly realized that I had neglected to swap over the timing (CPS) ring to the flywheel.
Once I got the flywheel off I noticed that there was no way the timing ring couldbe mounted on the back. the tapped holes were way off. After looking at it, I wonder if I got a 3.5 Flywheel. heres some pics.
All help is greatly appreciated, need any more info let me know.
Old May 22, 2009 | 07:56 AM
kzoosho's Avatar
Wow i cant help ya but im glad my fidanza came with the cps ring on it.
Old May 22, 2009 | 06:18 PM
pmohr's Avatar
No more Maximas...
What's the part number?
Have you called Fidanza?
Old May 23, 2009 | 05:54 PM
Snypa's Avatar
^^i bet not.
Old May 25, 2009 | 11:29 PM
got_max's Avatar
Wants a real car
The Part No. on the Box is 143991 NIS 12
on the Flywheel itself it is engraves Nis 12 5972
Old May 25, 2009 | 11:39 PM
pmohr's Avatar
No more Maximas...
Appears to be the correct part number. On the box, anyway.
So have you or have you not yet called Fidanza?
IIRC the VQ35 timing rings are welded onto the stock flywheels, and all aftermarket flywheels all come with them already in place.
Old May 26, 2009 | 06:06 PM
got_max's Avatar
Wants a real car
I stumbled across multiple threads here stating that the auto and manual timing rings are Identical, just they are rivited on the flex plate and bolted to the mt flywheel.
Is this possibly incorrect? What Im using is my auto timing ring that I drilled out
Old May 26, 2009 | 06:25 PM
pmohr's Avatar
No more Maximas...
I knew something in that pic looked weird.
The rings are completely different with respect to how they're mounted.
I'll get a pic up in a minute.
Should've mentioned that in the beginning, really.
The flywheel timing ring base goes from the step up from the center, to the step up by the ring gear.
As you can see, the timing ring on the flexplate has much less material than the flywheel timing ring.
So essentially your problem is you're trying to hack something up instead of using the correct part. When you get said correct part, it should bolt right up.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
