sevice engine soon light....help
my service engine soon light came on recently, any idea what could cause this?
the car gets frequent oil changes every 3k, the last time the tune up was done was in 2006. car has 178,000 miles and i havnt done anything.
please help
thanks
please help
thanks
Take the car to any autozone , they will check it for free...
or
Have an OBD II scanner and do it yourself,more than easy to do..search how to
or
Perform the screw methode ,easy...search how....
Come back with the results (codes)...
or
or
Are you serious? You've been here for 5 years and you post something like this?
Let me clue you in on the forum guidelines:
http://forums.maxima.org/4th-generat...ing-forum.html
wanted to know the quickest way to solve this problem....
just because im a member for 5 years doesnt mean im a professional mechanic.
if you have the page on how to solve this problem, pls send it to me as i could not find it.
thanks
We can't solve anything without the codes. Well, that's not true; you could pull the bulb out for the CEL, then you wouldn't have to see it anymore.
You don't need to be a 'professional mechanic', all you need is be able to read, and have a screwdriver.
Did you look in the stickies? It's aptly named:
http://forums.maxima.org/4th-generat...first-cel.html
It's impossible for us to help you figure out what your problem is without knowing what the codes and symptoms are. Find the code(s), then go from there.
Read here on how to get codes:
The quickest way is to pull the codes, and find out what the problem actually is.
thanks for the support, i think i can handle this and get the code, but as for fixing it once i know...i dont think i will temp it as im not good with fixing cars. will ask you guys for more help soon.
If you don't plan on fixing it just take it to a shop. They will scan the code diagnose the problem and fix it. However, some problems can be as simple as reading a how to, turning a wrench, and popping in a new part or sensor.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
