CEL with engine running but not in "ON" position, no codes
Old Jun 15, 2009 | 10:36 AM
agmetal's Avatar
The thread title pretty much describes the issue...I have no idea what's going on or where to look. I'm not noticing any real performance issues or hearing anything abnormal. To clarify, it comes on with the engine running, but if I only turn the key to "ON", or if I start it, then turn off the engine with the car still "ON", the CEL is not lit.
If it means anything, the CEL came on almost immediately after following a car pouring out exhaust smoke for a few blocks last night. Could it be that the other car's smoke got in my intake and tripped the CEL, and it doesn't actually mean anything?
Old Jun 15, 2009 | 09:44 PM
IlyaK's Avatar
The Golden One
Take it to a auto store and get your codes scanned then come back (or search on here how to do it).
We can't help you until you do.
Old Jun 15, 2009 | 09:54 PM
agmetal's Avatar
I'm quite familiar with how to check the codes on my own. I did that before I posted this thread. As stated in the thread title, there are no codes.
Old Jun 15, 2009 | 10:53 PM
djipka's Avatar
interesting. if you are right, I wanna know what happened and how
Old Jun 16, 2009 | 06:19 AM
cedric's Avatar
How about checking your ignition switch. The CEL should come on when its in the ON position and then go off when the motor is running.
Old Jun 16, 2009 | 11:47 AM
agmetal's Avatar
Check it how? Honestly, I'd be a bit surprised if the ignition switch was the issue, but I still have no idea what's going on. I'm gonna try checking for codes again later today.
Old Jun 16, 2009 | 04:31 PM
agmetal's Avatar
Tried checking for codes again today, also tried resetting the ECU...no luck.
Old Jun 16, 2009 | 04:57 PM
Product_Of_Korea's Avatar
usually when the CEL doesnt come on when just on the on positiion there is something wrong with the ECU. That is how one would usually see if the ECU is working correctly. If you have a spare ECU id try swapping it out
Old Jun 16, 2009 | 05:59 PM
agmetal's Avatar
I don't have an extra ECU, nor do I have the funds to pick one up.
kjlouis
Nov 24, 2018 06:09 AM
rtirbany
Sep 8, 2015 11:46 AM
Balkins
Aug 12, 2015 06:39 AM
