CEL IACV issue
Old Jun 19, 2009 | 05:17 PM
ish's Avatar
ish
CEL IACV issue
Whats up guys;
My Maxima has been idling at 1500 rpm's throwing code 0205 for the iacv. Cleaned, didnt work. Replaced, still getting the code. Now i just got code 0606. Just did a sprk plug replacement to NGK's last week? Any help would be great
Cant find out whats wrong with the IACV code. Wouldnt know what else to check. My idle is crazy. Please help.
Old Jun 20, 2009 | 04:57 AM
njmaxseltd's Avatar
Replace the IACV.
Old Jun 20, 2009 | 05:25 AM
maxina97's Avatar
hmm...had problems with the 0205 code last week. i cleaned it and adjusted the idle screw, hasn't come back since, "knock on wood". you did adjust the idle screw to try and get the idle down right?
Old Jun 20, 2009 | 06:54 AM
ish's Avatar
ish
I replaced it, and i did adjust the idle screw. One thing i did add this morning to the workload is the EGR tube cleanout.
So far so good. Idle went down alot but CEL still exists for the IACV.Did a relearn (clockwise - hold 2 secs - Counterclockwise on ecu). A little annoyed right now.
So new IACV, Clean EGR tube, but still getting the IACV code. Any Suggestions? Its driving well now.
Old Jun 21, 2009 | 12:29 AM
tosheto's Avatar
You have to turn it clockwise, wait at least 2 seconds and turn counterclockwise. Then you check the codes and repeat the procedure to erase the codes!
Old Jun 21, 2009 | 05:25 AM
maxima_million's Avatar
I ended up having nissan reset my edu via a odb2scanner. The car went through a 10 min process and my rpms were adjusted from 700
To 744. Just a thought!!
Old Jun 21, 2009 | 11:42 AM
DAVE Sz's Avatar
Hooooooonda.....
so nissan didn't do anything is what you're saying?
Old Jun 22, 2009 | 03:26 PM
96i30azn's Avatar
Hey if they can get rid of codes by not doing anything that you can't by doing everything, I'm all for it.
Old Jun 23, 2009 | 12:09 PM
Chris99SE's Avatar
i have a brand new nissan IACV if you need one. Never used, PM me.
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
ballerchris510
Sep 10, 2015 09:35 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
nbstriker10
Sep 4, 2015 04:26 PM
